FixYa.com
Tags:
Garmin StreetPilot i3 GPS Receiver
Garmin repair facility in Orange County
posted by olprica on Dec 01, 2007
I have a Garmin Streetpilot i3 in which the mini usb port got loosed from the board and needs to be resoldering. Do you now where in Orange County (zip 9265 can I found a repair facility for this problem.
Thank you,
Ernest
Comment by olprica, posted on Dec 01, 2007
I meant (zip 92656)
Comment by olprica, posted on Dec 31, 2007
Thank you for your insight. Unfortunately, these facilities won't accept responsability for a positive outcome!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
audiqv8
Rank:Guru Guru
Rating: 87%, 218 votes
  • Find a decent electronic repair facility. I usually super glue the broken mini USB connector to the circuit board and then solder the four support legs of the USB connector. Then there are 5 pins on the USB connector which must be solder back to the circuit board. The two outer pins supply power to the I3 and the remainin inner pins are for data. If this is a recent purchase (less than a year) then I would call Garmin. Good luck.
Rating Locked! (?) olprica has rated this solution as Helpful
Solution #2
posted on Apr 06, 2008
Not Rated (0)
lamourd
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
crack top screen where to go
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these GPS Devices problems?
Downloading music to my...
I have a feature on my new... Answer This...
charging the garmin 750
Hi, just got the garmin and... Answer This...
2009 map update
CD will not update my Garmin... Answer This...
lost map data
how do you re-install thanks... Answer This...
go through initial procedure to...
cannot load maps or register,... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
