Question about Mag Innovision LT776s 17" LCD Monitor
Monitor not working...sorta
I have a LT776s monitor from MAG, I have found many sites with the same problem I'm having. Anyway, I tested the LCD and backlight on another monitor I have, and it works fine, I also tested the speakers, and they work fine, while in the monitor, so I figure its not the powersupply or the lcd pannel itself. I pulled out a little board it has the vga connector and power input and 2 rca connectors in it. on a chip thing on the board it says MRT MASCOT VP2 R46711.1 0305 and it has a little wire thing that attached to the lcd pannel itself and it says 631-030-j007-D. I think this is the broken part, and all the parts are to small to soldier for myself, so I was wondering if you could tell me where to find the part. Thanks...
Dave
  • craiglane Dec 09, 2007
    I have that same monitor and when I hook it up the power led just blinks, any ideas? thanks
Sounds more like the backlights
Posted on Jan 26, 2008
I just changed my video card and after turning up my screen refresh rate (Hz) my monitor started doing the same thing. Monitor worked great for a long time but now its done! The only thing I can think of is that it has to have 60Hz, turn it up for gaming and its too sensitive to frequency. By the way, mine will turn on after a few power cycles.
Posted on Jan 04, 2008
SOURCE:
Does a MAG monitor model 900P have in built speakers?
Yes the Mag 900P has built in speakers. The audio lead for them is attached to the blue VGA connector and has a green tipped plug like a set of desktop speakers.
Oct 10, 2010 | Mag Innovision LT776s 17" LCD Monitor
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
Jan 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Monitor LT776s 17 flat
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 27, 2008 | Mag Innovision LT776s 17" LCD Monitor
No sound on mag monitor
well,maybe the speaker of your monitor is damages..and need for check-up and diagnose..
Jan 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
226 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
