Question about Motorola Mobility RAZR V3i Cellular Phone
Lcd screen When i open my screen there is problem.I think there's lcd screen's belt was break.
    An expert whose answer gotĀ voted for 100 times.
  • 111 Answers
There is a problem with the flex..might be damaged..have it replaced by a cellphone technician
Posted on Jan 28, 2008
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Lcd screen
Well, you're not going to fix this without opening up the camera.
The LCD screen should have to wires going to it. One is for the light that illuminates the LCD. That one is obviously working. The other is for the LCD itself - it sounds like that isn't. Either the LCD needs replaced, or that cable is loose or damaged. I'd suggest opening up the camera, finding that cable (it will likely be a thinner cable than the other), and checking for loose connections, or an obvious break or sharp bend in the cable.
Unfortunately, even if you find the cable is damaged, I'm not sure you can get it replaced. If you're not confident you can take this apart and put it back together properly, I'd suggest either taking it to a repair shop, or just using it as is. I'd hate to see you damage it further. If you are confident, however, check that cable. If it's good, contact Samsung about a replacement LCD.
Dec 20, 2007 | Samsung Digimax i5 Digital Camera
I cannot take pictures because the screen is will not show the view i want to can i fix this problem? pls help me :(
First of all you need to identify whether your LCD screen is bad or not. You can do this by shooting a picture and downloading it to your PC. If the picture is ok, then your LCD is bad. You need to replace the LCD screen. It is not cheap to replace it.
If your camera is under warranty, try to get it fixed on warranty terms.
A cheaper way, but time consuming. Try to replace the LCD yourself. Remember that you are doing it on your own risk. Warranty becomes void once you open the camera.
Learn some basics from websites. Look at the following web sites:
If you think you can do it, then buy a jewellers screwdriver set for $1 from Dollar store. Bua a used camera (a similar one sold for parts, but with good LCD) through You have to look for it. You may be able to get it very cheap, may be under $15. Remove the casing on the camera (5-6 screws). Carefully and gently remove the casing, dont break it. Once you open it, usually LCD is immediately accessible.
Jan 18, 2011 | General Electric A950 Digital Camera
When I open my cellphone, little lines appear at the bottom of the screen and quickly spread all over the screen, making viewing texts and stuff next to impossible
it happens when the connection belt got damage . connection belt which connect the mother to LCD. that is why LCD ( screen )does not show any thing.
Jan 02, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
My canon sd10 digital camera lcd balnk/black bu tphoto view in lcd ..lcd like screen bu photo not show in screen so i donot photo capture
Had the same problem with my SD10. The switch in the AV port sometimes gets dirty or corroded, and tricks the camera into thinking that an AV plug is inserted. This will turn off the screen.
To fix it, repeatedly insert and remove an AV cable into the port several times. This may help break off any corrosion or dirt that may be holding this switch open.
Nov 08, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Do the valves connect with the pistons on the 1992 plymoth voyage
you should be ok.. i have never seen valve damage on one of these engines after belt breaking..just retime everything and install a new belt..make sure you check water pump and tensioner bearing for looseness/wear
Nov 05, 2009 | Chrysler Voyager Cars & Trucks
Flat screen TV has a leak inside, I think. At the
What technology is this TV? LCD? Plasma? DLP? LCD screens can break fairly easily. The liquid crystals are "grown", and they are very thin. If the glass is not cracked, then there may be a problem with the "ribbon cables" that connect the thousands of pixels to the processor. Moving the ribbons a tiny bit may make it work. If this does solve it, use clear tape to hold them in place.
Jun 30, 2009 | Hitachi 50V720 Television
Open a Dell S1909 LCD display
wouldnt it be easier to plug it into another computer and see if it still does it? if not its your video card in the pc, if it does than its the screen and most likely its shot if thats the case...
Mar 31, 2009 | Dell Studio Slim-Tower Desktop Computer
Zire 71 screen
Two possible scenarios:
1. Loose LCD screen connector inside the pda. You will need to open it and put it right.
It requires some level of skills to open it, repair it, close it properly.
If not precautions are taken, there are two major risks:
a) Break the flat ribbon cable of the universal PalmOne port (used to synchronize it and charge it).
b) Break a tiny switch that detects when is slided the top side so the camera application turns on.
2. LCD screen is damaged. It needs replacement.
You can get in touch with local repair services for it, and request a quote for its diagnostics and repair.
If after get some quotes, you think that they are excessive, you can contact the Ebay seller Great_items_2004 to receive a lower quote for it.
Jul 08, 2008 | Palm Zire 71 Handheld
LCD screen
ahemm sir its soo easy but be carefull u might break it and take note its propper position thankss and hope too help you,,,gud luck!!
Mar 04, 2008 | LG Shine KE970 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
