Question about 3M - EVD Projection Lamp for Overhead Projectors Multimedia Projector
3m Pverhead projector not working need help!
The overhead projector in our Church is not working, checked with the bulb, but looks like the bulb is okay.
Check for corrosion where the bulb sits in. Is there a fuse required. Make sure you handle the buld with cotton gloves (oil from hands not good) Let me know if that works.
Posted on Feb 27, 2009
SOURCE:
The lights won't turn on We put in new bulbs, etc.
Check and see if you have a reset button. Some do and some do not.
See if you have power going to the wires
Make sure your plug is working properly. If you have frayed wires that could cause trouble as well.
Oct 03, 2015 | 3M 1800 Series Overhead Projectors—Product...
Fan works, light doesn't - replacing lamp doesn't help. Suspect electrical problem. Is it fixable and cost effective?
Diane,
Your bulb socket has probably burned out. As far as being cost effective, that would depend on whether you could find a new socket and how much someone would charge to put it in if you were not wanting to try yourself.
May 21, 2015 | 3M Model 1720 Overhead Projector 1700 BJV
I have a older overhead projector that I need a bulb for but can't find the right bulb where can I find the bulb at......
You can provide the model # for the projector or possibly look at the actual old bulb to obtain any identification data from the bulb - such as a part #.
Here is a link for 3m replacement lamps:
3M Canada Office 3M Overhead Projector Lamps
Jan 06, 2015 | 3M Office Equipment & Supplies
I have a. 3m overhead that doesn't work well, help?
What is wrong with it specifically - are you setting it up correctly, does the bulb work, is it focused, etc?
Dec 11, 2013 | Office Equipment & Supplies
Assembling 3m 9100 projector
<a href="http://www.projectorsuperstore.com/">Projector SuperStore</a> is your one stop shop for all things presentaiton. Projector SuperStore is your number one resource for Presentation Equipment including Projectors and Projector Accessories from Panasonic, EPSON, Sanyo, Sony, Mitsubishi, InFocus, NEC and more. Visit: <a href="http://www.projectorsuperstore.com/">http://www.projectorsuperstore.com/</a>
Aug 29, 2012 | 3 m 3m 9100 Overhead Projector
I have a 3M 1700 Overhead Projector. After about two months of use, my bulb stopped working, so I replaced it with a new bulb. When I turned on the projector, there was a slight "pop" and the...
Take the lamp out and check for physical damage. Some lamps come defective and can shad (brake glass inside) upon warming up. The "pop" sound could be it.
Feb 12, 2011 | Office Equipment & Supplies
My overhead projector...it does not light up....the fan goes on but no light.
projector goes on then goes out. orange light on solid and flashing blue.
have had optoma look at it they said it was bulb.
Oct 23, 2009 | 3M EVW Overhead Projector Replacement Lamp...
I changed the bulb in the overhead but the light does not go on. The fan does. What next
open casing - turn power on and check whether bulb at least flickers - if not perhaps you have touched the bulb itself and static has wrecked it
Sep 25, 2009 | 3M - FCS Projection Lamp for 1610,...
542 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Lampdeng.com
Lampdeng.com
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
