Question about Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset
Samsung 200 bluetooth
I lost my manual and now i am trying to pair my bluetooth with my new blackberry phone, but it keeps asking me for a device code????
    Problem Solver:
  • 5 Answers
I had the same problem. To fix this, you need to keep hold of the button when you are turning it on until the light stays on - this is pairing mode. When the light is on, search for it on your phone and pair them up.
Posted on Sep 21, 2009
It is 0000
Posted on Oct 06, 2008
  • 4 Answers
Try the samsung website, www.samsung.com - there are a couple of steps, but look for the support and/or download links.
Posted on Dec 01, 2007
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How do I pair my WEP 200 samsung bluetooth to my phone blackberry phone
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
Oct 14, 2009 | Samsung WEP200 Headset
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Lost my manual for my sph-m800 want to hook up bluetooth
turn your headset on and hold the button down until it starts flashing blue and red. go to setting on your phone bluetooth and choose add new device or pair device.
your phone will pik up the new bluetooth and ask for a password it is usually 0000 or 1234
Jun 02, 2009 | Cell Phones
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Pairing headset with Blackberry Pearl
On my blackberry I have to turn bluetooth on. Then on the WEP 200 hold down the button untill you hear a series of beeps. The light should blink every so often once its on. Then go to bluetooth options and search for devices.
Jun 07, 2008 | Samsung WEP200 Headset
Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset Logo
615 people viewed this question
Top Eforcity Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you an Eforcity Radio Communication Expert? Answer questions, earn points and help others
