Question about Philips MMS 460 Computer Speakers
Speakers Buzzing Whilst Playing Music
Okay well, I bought this system yesterday and after fixing it up properly to my computer and getting past a few minor problems it was working great.
However after a while i noticed that my speakers started to buzz whilst playing music, now, I'm not playing my music loud at all it's less than a quarter of the way but the speakers still buzz..
Any ideas?
  • vixen75 Jan 02, 2008
    am having the same prob , but have had my speakers 4 over 2 years now, with no probs until now , just upgarded my screen from a 17" to a 24", since i done that am getting an horrid humming with or without music playing, its driving me nuts , have moved speakers away from screen , moved sub as far away as it will go , but still the same, have checked all connections , still no wiser ,i have all the latest drivers 4 my sound card, i am lost ???
    can any1 shed some light on the prob , or will i just have 2 look 2 buying new speaker system
Those speakers are not magnetically shielded, shielded speakers resist buzzing caused by monitors. Just about any decent computer speakers on the market today are shielded, and will most likely state that on the box. Apart from moving the speakers farther away from the monitor, there is little you can do to avoid this interference.
Posted on Aug 30, 2008
    Problem Solver:
  • 10 Answers
Sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Posted on Dec 02, 2007
it is probably a problem with your graphic card's drivers or the card itself
Apr 17, 2014 | Dell Computers & Internet
How do Istall rtl120.bpl as this is mising and I get this notice every time I turn on my computer
I understand the inconvenience. It may happen due to automatic updates. Since, it is happening from yesterday, I would recommend to run a system restore to the previous date. To do so:
1. Click Start Menu> All Programs> System Tools> System restore
2. Select a previous date on which the computer was working
Note: If any change were made to the computer, it will be erased.
Please revert back to me for any clarification.
Thanks and regards,
Dec 07, 2011 | Acer Aspire M3400 PC Desktop
I have a 91 tercel that will not pass smog, unable to read codes, idles too high that if you put the car in gear before it warms up its jerks hard, appears to idle normally after warmed up, smokes pretty...
The smoking is probably due to worn valve guides.. the oil from the top..the head.. is leaking past the valve stem into the cylinder.. next morning or a few hours later when you start the car.. it burns this oil up..and the problem although still there is much less noticeable.. cause the amount leaking is's being burned as you drive.. otherwise it takes a while for it to accumulate.. It could mean a minor head/top end rebuild to a minor overhaul..
The emissions problem and the idle problem may be linked.
First make sure your throttle cable is clean and working properly. They can get dirty.. sticky..or even a weak spring.. but dirt rust and grime..biggest culprits.
There is an IAC (Idle air control) valve attached to the throttle body.. you may be able to spray carb cleaner into the closed throttle body to clean it.. You may need to replace this part. It can really get clogged with carbon.. and cause this high idle problem.
Next.. replace or remove/clean/reinstall the EGR valve...probably better off just replacing it.
Check all vacuum lines for cracks..replace as needed..vacuum hose is cheap.. and lastly.. do a minor tune up.. plug wires.. plugs (properly gapped of course). air filter and fuel filter..
Your car will probably pass the smog check even with the cold startup burning oil issue.. that's not what's causing it to's the EGR valve and possilbe lack of recent tune up.
You can continue to add oil between changes.. use a heavier weight.. and check often.. Once consumption gets more than a quart or so between can contemplate the real fix... or start pouring anything with the word miracle into it.(grin).
Great little car.. Best of luck!
Apr 22, 2011 | 1991 Toyota Tercel
,My Xbox 360(Pro 20GB hard drive bought 2 years ago no problems until now) keeps freezing just after i turn it on. Most of the time it freezes on the first loading screen but some times it works for a bit...
sounds an update issue. u get an update but it makes ur system go crazy and not work properly.this is a known problem
try clearing ur hardrive cache. that all i know of to fix that problem.
Oct 25, 2010 | Microsoft Xbox 360 Console
87 camry. we're replaced the starter, distributor
If you are trying to get the car to start easier you still may be venting through the gas line or gas cap. The new fuel line may solve the problem. What you still can do is replace the gas cap.
Both Autozone and O'reilly will test your car free. The system on an 87 model may not generate a trouble code on your dash for the problem you have. But the test gauge may show it.
If the car has zip the fuel pump may be okay. If the car fast idles briefly when cold, the cold start system is working. If the car does not idle up, the cold start system is not resetting.
Jul 17, 2009 | 1987 Toyota Camry
Random powering down of my Z-5500s?
I have the same problem, logitech replaced the whole system under the warranty
May 21, 2008 | Logitech Z-5500 Computer Speakers
E-machine T3085 video card problem?
yeppers..that video card sounds up machine first, and make certain it's still seated properly.
got backup for that E machine?
Feb 21, 2008 | Computers & Internet
2 problems with my coby mp3 player
I have the same problem just bought the thing yesterday and it won't charge I downloaded music yesterday and charged it, now it isn't recognized by the computer.
Went thru the whole troubleshooting chart and nothing happened, I did email techsupport but haven't heard anything. I guess I'll take the thing back and get it replaced.
Jan 03, 2008 | Coby MP-C582 MP3 Player
Thm505 no sound
Nov 06, 2007 | JVC TH-M505 System
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
Philips MMS 460 Computer Speakers Logo
519 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
