Question about E-Machines eMachines Desktop PC
EMachine won't turn on
My eMachine desktop will not turn on. We have tried different outlets, and it won't work in any of them. It is about 3 years old.
  • 2 more comments
  • Anonymous Dec 11, 2007
    my emachine will not turn on. It made sounds for awhile as if the fan was going. Will I lose all of my info within my computer? Help........
  • DSINS7 Dec 15, 2007
    I HAVE AN EMACHINE DESKTOP AT FIRST I HAD TO HOLD IN THE START BUTTON AND THE FAN SLOWLY REV UP AND THEN THE COMPUTER WOULD START.
    THE LAST TIME IT WOULD NOT START AT ALL I REPLACED THE POWER SUPPLY AND THE COMPUTER STILL DID NOT START. HOW CAN I TEST THE ON & OFF SWITCH?????? HELP
  • Anonymous Feb 11, 2008
    already switch the power box and and cord to the computer and still does not turn on. Could it be the starting button or the mother board was damage by the outage of the power box. Please help.
    My computer will not power up. Replace the electrical cord that goes to the house outlet. Switch the power box(the one that I romoved was not working. Still no power at all. Please help. Could it be also the power switch or the mother board also was damage? Thanks in advance for any comment on my problem.
  • 383 Answers
Unplug the power cords and let it sit for about 5 to 10 min. just like the cable box sometimes the brains have to be reset than make sure all plugs a lined up and tight .
Hope this gets ya back on line.
Posted on Dec 01, 2007
    Novelist:
  • 127 Answers
1) Wont turn on at all:
- Test the power outlet with some other electric device for energy.
- be sure the power cable to the back of the CPU is well tighten in place. Take it out and look for burnt smell or signs. If not sure try pushing it in and try to turn computer on, try moving it firmly to all directions and try to turn it on to see if the CPU give you life signals or an easier way is to use the monitor power cable if compatible. If you get a intent to turn on from your CPU the is most likelly you have to change the power cable.
- If nothing of previous work, you may have a burnt CPU power supply that would cause other damages in your computer depending on the damage. Very often the protections into the power supply block any power line peaks to save the mainboard so you can try to shift power supplies or buy a new one though theres no warranty non any other part of your PC is broken also.
2) Wont show anything on screen, you can hear sounds from the CPU. the keyboard leds turn on, any CPU leds turn on;
- Check for loosen video conector.
- Bended or broken pins on video conector.
- Any loosen card, ram module, conectors inside the CPU (to check into the CPU body you need tools and this can void any warranty)
Good Luck...
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Jan 19, 2016 | eMachines MB.NBK09.003 Motherboard El1850...
My computer wont power on
Check the power cord at the wall and the machine. Try a different outlet. Check that the power supply dies not have a switch on the back of the pc for a different power setting. If all else fails, it might have a bad power supply.
Nov 12, 2012 | E-Machines eMachines Desktop PC
My emachine won't power up.
Power is not working.replace the power cord and check if it stays the same then your power box is not working.
Jul 16, 2012 | E-Machines eMachines Desktop PC
My emachine desktop monitor keeps cutting on and off by itself. What should I do?...it's really aggravating.
There are three possible reasons for the issue:
1. Monitor power cable is loose
2. Video Adapter is faulty
3. Monitor capacitor is gone bad
Please try the below steps to diagnose the issue:
1. Check the power cable on the back on Monitor, if connected properly, like connect the power cord on a different Wall outlet
2. Unplug the signal cable from the video adapter and replug it. Also, check a different monitor (if any) on the Tower.
3. If the above steps fails, then the issue is with the monitor, it is going for repair.
Thanks and regards,
Jitha
Nov 23, 2010 | Computers & Internet
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
My computer will not turn on it will not do anything, i remember hearing something blow like a fuse, it is connected to a surge protector it was the only thing that messed up
you fried your power supply inside the computer. check all connections and try plugging directly to known good outlet first. but it sounds like a blown power supply
Jul 16, 2009 | E-Machines eMachines Desktop PC
W2686
Your problem would not be with a battery, but the power supply. Try plugging into a different outlet just to make sure, but sounds like you may need a new power supply.
Jun 11, 2009 | E-Machines eMachines W2686 PC Desktop
No sound
ok my friend seems that you have issue with the sound driver
go to this website.
http://www.emachines.com/support/product_support.html
select your computer model
download the driver and enjoy the music
cheers
Aug 30, 2008 | E-Machines eMachines Desktop PC
2 year old E machine
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Jul 29, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
157 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
