How to solve sc324 error code richo copier aficio 5000
SOURCE:
  • 19 Answers
SOURCE: Richo Aficio 450e photocopy machine (Error Code SC360)
Replace HDD
Posted on Dec 24, 2008
SOURCE: richo copier 1060,error code sc-501
what is error SE541 on Ricoh 1060
Posted on Mar 27, 2009
  • 163 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
santosj27
  • 263 Answers
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
Posted on May 11, 2011
  • 36 Answers
SOURCE: error code sc 390 code richo aficio 2045
That error is related to a bed reading in a sensor of the Development Unit, called "TD sensor".
You can try to take out the development unit and see if there is dust of toner or even if the plug is broken.
The development unit is placed under the PCU.
Open the front door and you will see it.
If you can not see anything abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
Posted on Jun 02, 2011
How can i solve error code sc:901 in richo africo 2000 copier
The mechanical counter is either unplugged or is defective.
Oct 30, 2013 | Ricoh Aficio MP 2000 Black and White...
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
RICHO AFICIO 650 SHOW ERROR 890
there soesnt seem to be an error 890 on system but 880 is mlb you could try and go into the service mode by pressing clear yellow button and then press 107 and hold down the stop button.. thsi lets you into the service screen you want copier sp select 5. mode and go to 5-810 sc reset press execute and turn machine off wait and turn back on it coul djust be a signal error for the address book.. good luck A
Jun 12, 2009 | Ricoh Aficio 1018D Copier
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Richo 1045
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Jan 07, 2008 | Ricoh Aficio 450 Copier
19 people viewed this question
k24674
Marvin
Marvin
