Question about Sony KP-53S65 53" Rear Projection Television
Conversion of PAL (B) into NTSC
My friend brought a Sony KP-53S65 Rear Projection TV from the US. He went back but gave the TV to me. The TV just does not work! I am told that it is because in India we have PAL (B) signals whereas in US it is the NTSC. Hence I require to convert the sgnal input to NTSC.
Kindly advise the best method to achieve the result.
Thanks
Col Chand
[email protected]
  • 1 more comment
  • colchand Jan 01, 2008
    Wish you all a very happy New Year.
    Thanks a lot for the solution.
    But what should be the specifications of the converter to convert Pal B signals to NTSC for Sony KP-53S65 Rear Projection 53" TV 1998 model?
    Col Chand
  • ngoping Feb 17, 2009
    my friend bought a camcorder Samsung vp-d835i and she can't view it on her tv screen here in the US bec. it is PAL.
  • ngoping May 11, 2010
    just any video converter would do?
    Sergeant:
    Champion:
  • 346 Answers
You will need a pal/ntsc digital video converter
Posted on Jan 01, 2008
SOURCE:
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
The tv has no power its a sony kp-53s65 no light or nothing
hello you may to check the glass fuse inside the tv it will be in the power supply if it's black in colour it's blown make sure you put in the same rated fuse back in the value will be at the end of the fuse or on the fuse holder on the power supply board but beware if it blows again then you have a dead short inside the tv someware good luck
regards
shaun
Jul 29, 2010 | Sony KP-53S65 53" Rear Projection...
I need to replace the bulb in kp-53s65
This TV does not have a lamp only 3 CTR tubes which bulb are you looking for?
Jul 11, 2009 | Sony KP-53S65 53" Rear Projection...
Tv wont turn on.. :-<
It is the capacitor. Look in other forum for part number. I had exact same problem. Was a $2.00 part.
Feb 01, 2009 | Sony KP-53S65 53" Rear Projection...
Will My Sony work Overseas
your users manual should tell you if it is a pal and ntsc system it will, thay do make ntsc to PAL convershiom box cost about $139
Jan 09, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony kp-53s65
i have a sound no picture
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
128 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
