Question about HP OfficeJet D135 All-In-One InkJet Printer
How to clean printheads
What is the procedure on cleaning printheads what solution do I use?
  • dodido Dec 19, 2007
    How can you tell which color printhead needs replacing?
  • 150 Answers
There are two things that you can do...
Clean printheads, because of ink buildup, or clean the heads and contacts because of debris buildup.
  1. Clean the printheads; this is done when there is streaking in the printout
    1. Press Menu
    2. Press 7 (Status Maintenance Menu)
    3. then 2 (Clean Printheads)
    4. Check print out. If it's still bad, then replace the printhead that's not working.
  2. Clean the ink cartridge contacts
    1. Using a clean lint-free cloth, distilled or filtered water (no tap water)
    2. Open the print-cartridge access door
    3. After cartridges are in center, unplug unit
    4. Remove the cartridges
    5. Examine contacts for debris buildup
    6. With damp cloth clean any debris buildup on cartridge or in cartridge bed
    7. Repeat for others
    8. Replace all and turn on printer
    9. Message will appear to Re-align heads, press enter to do this
If this helped, please rate FixYa!, ThankYa!
Posted on Dec 01, 2007
  • 353 Answers
SOURCE: is there a way of manually cleaning a printhead?
Are you confident you have a good Cyan cartridge from which the ink is flowing properly. For example, are you sure you removed the yellow tape from the cartridge before you installed it? Is it low on ink? Even though the Status Monitor says the cartridge has plenty of ink, it may not. This is because the Status Monitor only estimates how much an ink cartridge contains based on how much printing & head cleaning has been carried out since new. There are a number of reasons for it to get it badly wrong, or it may simply be faulty (e.g. an out-of-date cartridge that has dried-up). If in doubt change it for a new one.
Apart from a dud cartridge, air trapped in the nozzles can inhibit ink flowing. This is usually caused by unsatisfactory cartridge replacement e.g. taking out the old cartridge too long before installing the new. Tackle this with head cleaning cycles. But, do not carry out more than 2 or 3 cleaning cycles in a row; once ink starts to flow, as shown by a nozzle check print, leave it to stand for 24 hours before trying 2 or 3 cycles again. Patience is the key.
If these steps produce no improvement, then you can try the following head-soak process. Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two again. If still nothing, report back.
Posted on Feb 10, 2009
  • 10406 Answers
SOURCE: Printhead cleaning
Turn the printer off.
Turn the printer on.
Restart your computer.
Try to print -- has the message vanished?
Posted on Nov 18, 2009
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
  • 23 Answers
SOURCE: How do you clean HP 6940 printhead?
Remove the ink cartridge and gently clean the printer head (shiny silver wafer) with hot water, glass cleaner, or isopropyl alcohol and a cotton swab. Run the HP head cleaner with the software that was supplied with your printer afterward. Visit if you need the software or your user manual.
Posted on Sep 29, 2009
  • 619 Answers
SOURCE: printhead cleaning
Hi, in desktop right side down you can see the printer icon click right select head cleaning.
Posted on Mar 01, 2008
Clean or replace print head
The printhead is a non-replaceable part. There is a printhead cleaning procedure available through the device's menus. You might want to try performing the procedure numerous times.
Jun 23, 2015 | HP Officejet 6700 Premium E-All-In-One...
My canon mx452 keeps sending a message on screen saying printer not responding.I have run a diagnosis and it says no problem.
Make sure you are getting blank printouts when printing from the printers control panel, not just your computer. If it's printing blanks from both of these procedures, the focus would be on the "Printhead". Some Printheads are easy to remove, sits under the inks. Should be a grey latch you release to get access to the printhead. (remove inks first). Soak this printhead in a solution of windex, about a quarter inch deep, for about 20 minutes, wipe clean with isopropol alcohol and reinstall in your printer and do another alignment / cleaning procedure. If this does'nt fix the issue, you might try replacing the Printhead or retiring this printer.
Mar 02, 2015 | Canon Pixma MX452
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
Hp officejet 6500 e709n print quality poor even after replacing print head
For severe print quality/missing color issues there could be an air bubble/air gaps in the printer ink lines or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest.
For more information please visit:
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here:
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
When instaling new ink carchage it won't print clearly. Is there any printing Mantainace software that can downloaded.
Clean the printhead
If your printed output is streaked or has any incorrect or missing colors, the printhead
might need to be cleaned.
This process uses ink to attempt to unclog and clean the nozzles in the printhead.
This might take a few minutes and will use one or more sheets of paper.
To clean the printhead from the control panel
1. Load letter, A4, or legal unused plain white paper into the main input tray.
2. Press Setup.
3. Press the down arrow button to highlight Tools, and then press OK.
4. Press the down arrow button to highlight Clean Printhead, and then press OK.
The product cleans the printhead.
5. Press any button to return to the Tools menu.
To clean the printhead from the Printer Toolbox
2. In the HP Solution Center, click Settings.
Work with ink cartridges 1513. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Clean Printhead.
6. Follow the prompts until you are satisfied with the quality of the output, and then click
There are two stages of cleaning. Each stage lasts about two minutes, uses one sheet
of paper, and uses an increasing amount of ink. After each stage, review the quality
of the printed page. You should only initiate the next phase of cleaning if the print
quality is poor.
If print quality still seems poor after you complete both stages of cleaning, try aligning
the printer. If print quality problems persist after cleaning and aligning, contact HP
To clean the printhead from the embedded Web server
2. Click the Device Settings tab, click Device Services in the left pane, select Clean
Printheads from the drop-down list in the Print Quality section, and then click Run
Good luck................Pete
Jul 15, 2011 | HP Officejet 6500 Wireless All-in-One...
My printer Canon MP760 does not print black.
Your black ink must be empty replace with a new one and print.
Sep 20, 2009 | Office Equipment & Supplies
Bar code is not dark enough, can it be cleaned
Turn up the darkness setting. Here is a video on how to clean a printer, it isn't the same model but the procedure on the printhead is the same. At about 50 seconds into the video it shows the printhead which is basically the same on the LP2824.
Jun 25, 2009 | Zebra TLP 2824 Printer
How Clean the Head of HP2600n Laser jet printer
There is technically no "printhead" on a Laser Jet printer. There is a cleaning cycle though. Press the menu button and navigate left to the Service menu, click right and then select the cleaning option.
Jun 04, 2009 | HP Color LaserJet 2600n Printer
It sounds like the printheads are dirty or you have a leaking cartridge. Take the printheads out and clean them with a damp cloth. Just in case you haven't done it yet, do the printhead cleaning procedure. Also try temporarily lowering the print quality and see if the symptom changes.
Mar 10, 2009 | HP Business InkJet 2800 Printer
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
7,525 people viewed this question
Ben Johnson
