Audio problems with 805 Onkyo A/V receiver
I have a 805 Onkyo receiver hooked up to a BD-1400 Samsung Blu-ray. The Samsung is capable of bitstreaming the loseless audio to the receiver and the receiver is suppose to be able to decode HD-MA and True Dolby-HD, which it shows on the front panel. The problem is all digital audio creates a muzzled sound in the speaker when people are speaking, unless I turn to the receiver to ALL Channel Stereo. Need help with this problem
4 Suggested Answers
SOURCE:
SOURCE: onkyo sr 605
tryed that still not working been told that the player will not send bitstream audio only to the receiver there for it decodes the signal on board the blu ray player so the tru hd light does not light up.
Posted on Mar 24, 2008
  • 905 Answers
SOURCE: No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Posted on Oct 06, 2008
SOURCE: No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Posted on Jan 26, 2009
Denon AVR-988 receiver not working surround output when playing movie in my samsung blu ray BD-1400 player
Be sure in the menu setting that the audio analog/digital setting is correct for the blu ray setting. All try the factory reset as stated in owners manual
Feb 18, 2015 | Denon Audio Players & Recorders
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
Hello what is the best setting for ps3 slim when played through onkyo 608 pcm or bitstream at the moment it is saying multichanel on the amp if i change it to bitstream it says on the screen some audio...
Bitstream will pass the HD digital audio directly on to the receiver, in either DTS or Dolby format. This allows your receiver to decode these formats. The Onkyo TX-SR608 is capable of decoding all the new HD audio formats, and has quality Burr-Brown digital-analogue converters so it would be a shame not to use bitstream in my opinion.
Electing to output the sound as PCM will utilize the PS3's internal digital audio decoding, and I believe output a two channel analogue signal... which your receiver will then reprocess into simulated surround sound... not ideal really.
Jan 06, 2011 | Onkyo TX-SR608 Receiver
I have onkyo receiver model tx-sr606. I just bought samsung bluray player model BD-C6500. I tried all remote codes from the receiver manuall but nono worked. Could u please tell me the remote code for...
I have heard several complaints about this problem. Unfortunately, none of those codes work for the blu-ray player. I also ask Samsung Techs product support, and was told the TV remote cannot be programmed to run the blu-ray.
Just contact with the service in your zone and buy new one, the price really is very short and solve the problem so fast. I suggest contact directly with the Samsung Support.
I'm sorry sendn more details about this, but hope helps.
Jul 14, 2010 | Audio Players & Recorders
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Need Onkyo SR803 Remote code for Samsung BD-P1590
This should help you.
http://codesforuniversalremotes.com/samsung-blu-ray-player-remote-control-codes/
Dec 02, 2017 | Onkyo TX-SR705 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
Samsung BD p 1400 locking up.. did you find a fix yet?
I have a BD-P1000 and while playing a discit just stopped DEAD!
What can this be! It was also locking up, and would not play Blu-Ray discs? 609-296-6841 Dominick
Aug 18, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
here is more info
May 19, 2008 | Marantz SR-7200 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
82 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
