Question about Canon Powershot SD450 / IXUS 55 Digital Camera
SD450 all the taken pictures are bright white, but video mode still works
Don't why this problem comes out.
In picture mode, all the taken pictures are bright white, can't see anything. However, video mode still works properly. I tried all the settings. Still has the same problem. Does anyone know whether this is fixable ?
  • 1 more comment
  • sd450bad Dec 04, 2007
    I did try to reset and remove the battery. Unfortunately, the problem is still there. (There is no firmware which I can download from Canon's site.)
    Anyway, thank you very much for your suggestion.
  • djtv Jan 07, 2008
    i have the same problem as well. i've reset the settings, removed the battery, looked for firmware, tried outdoor settings, adjusted the white balance... nothing works. it's not the same anymore. had the camera for over a year now. please help!
  • Anonymous Mar 03, 2008
    Having the exact same problem, and have tried all the standard fixes and nothing works. If anyone has fixed this, please post!
    Scholar:
  • 48 Answers
Sounds to me like your auto white balance is on the fritz.
First thing I would do is reset the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Canon's website and look for firmware updates. Download and install them.
If that doesn't work, see what happens on the various other settings like cloudy, daylight, tungsten, etc. Then try setting a custom white balance.
If all else fails, you may be looking at a servicing/repair and with the average repair costing $180, if your warranty is expired it may cost more to repair than it's worth. The rule of thumb is that if the estimate for repair is north of 50% what you paid for it, you're better off taking that money and buying a newer and upgraded model.
JD
Digital-Camera HQ
Posted on Dec 01, 2007
All outside pictures come out very white. Inside seems to be okay. Have tried 'reset' but still no good.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 04, 2011 | Casio Exilim EX-S600 Digital Camera
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
May 29, 2011 | Samsung S1070 Digital Camera
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Casio Exilim EX-S600D creates "white pictures"
Check the ISO setting...it may be too high. Also, check the white balance.
Sep 04, 2009 | Casio Exilim EX-S500 Digital Camera
Screen does not show images
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Video is too white/bright outside. Can see nothing but white on v
I can not use my camera when taking pictures outside .it just shows up too bright. I don't know what I did as I have taken picture before.Can someone tell me how to find the correct setting menu?
May 07, 2009 | Olympus Camedia C-770 Digital Camera
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Pictures taken during the day come out VERY bright, even white
Might be worth flicking through all the settings menus for a few minutes - look in particular to see if you've got it out of Auto into Manual Exposure, or if somebody has accidentally selected a "brighten everything up by a couple of stops" mode. A.
Jun 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
237 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
