Question about Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz flash 58 AF exploded
Hi there. Same happened to me. My flash bulb exploded. I have no idea how to get one replaced though. Does anyone know how to get new flash bulb installed?
    Sniper:
  • 92 Answers
If you are interested to buy new
Metz 58 AF-1 FLASH f / NIKON TTL Flash
click the link below
http://www.amazon.com/Metz-MZ-58314N-Flash-Cameras/dp/B000M21J56
The replacement of bulb is simple, just push front cover upward and pull it outward the cover will be opend. Now pull out bulb and place a new one and shut the front cover gently.
Thanks eo share your problem with FIX YA.
Posted on Aug 16, 2009
    Champion:
  • 261 Answers
I repairs cameras/flashes/lens and studio lighting.
atdlee@netzero.com
Posted on Jan 14, 2010
    New Friend:
  • 30 Answers
Flash bulbs are obsolete parts of the film era. They were last used in the eighties of the past century, on Polaroids and miniature cameras. Their distinctive characteristics is that they can be used only once.
Metz 58 series, like all modern photo flashes, utilize flash tube.
I have never seen a flash tube exploded or blown. Those installed in brand equipment like Metz are made of quartz glass, are sturdy and withstand rather big stress. However, if it explode, the shattering glass spills render the fragile mirror around the tube and the front window unserviceable, so replacing the tube alone would not be enough. Replacing the flash tube is not that easy though. All three connections are soldered and in order to access them the flash has to be fully disassembled. Manufacturers use dirty tricks in order to hide the screws, linkages and other joints that hold the housing parts together.
On the other hand, flash capacitors that hold rather high amount of energy used to explode sometimes. Unfortunately, such event is fatal for a delicate electronic instrument, I believe it is beyond economic repair, following such an explosion.
Posted on Feb 01, 2015
    Genius:
  • 1,036 Answers
If it is still within a reasonable warranty period, I would take it bach to thestore you bought it.
If not, then contact the manufacturer directly as it may be manufacturing defect. If it is, then they should offer a replacement service.
They will be the best to advise on the correct replacement - or supply the part to you direct for a little DIY soldering.
SOURCE:
Metz 58 af-2 spares
Contact atdleeatnetzerodotcom
Feb 03, 2014 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 58 af-2 front flash lens brunt out
There are no consumer serviceable parts. Repair or replace the unit. Good luck.
Feb 03, 2014 | Metz Mecablitz 58 Af-2 Ttl Shoe Mount...
How to open metz
They are snap on & some need t torx bit to remove those screw.
atdlee@netzero.com
Jan 22, 2013 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I had metz 58 af for nikon mount can i convert it to canon mount
No. The Metz 58 is not designed as a part of a modular system.
Aug 10, 2011 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I'm new to photography and have a Nikon D-50 with a Metz 58 AF-1 digital flash. Where can I find a users manual?
Metz 58 AF-1:
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_58_AF_1_digital_Nikon_D_F_NL_GB_I_E.pdf
Nikon D50:
http://support.nikontech.com/app/answers/detail/a_id/13644
Sep 04, 2010 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 58 - broken
Take out batteries
Put in 4 new Energizer Lit. Bat in.
Turn on flash
Wait for the ready ready, fully charged
Press the test button out.
Flash should be able to be fired.
atdlee@netzero.com
Aug 13, 2007 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Open Questions:
Metz 58 AF-1 FLASH f/NIKON TTL Flash Logo
1,897 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
