Question about EliteGroup nForce3-A Motherboard
I lost my manual on hooking up the wiring on my nforce3-a motherboard.
I can not remember where the wires go on the motherboard. My manual is lost. I have disconected all the wires to put it into a bigger box and now I am stuck with no manual. Can you help? Thanks.
[email protected]
nforce3-a motherboard. Ineed to know how to connect the wires back up.
  • gsdmgrant Feb 11, 2009
    i lost my book with the wiring diagram in it and now i have all the wires unhooked and dont remember where they go cant remember the name of the mother board either so now what to do ?
    Scholar:
  • 48 Answers
Chances are, you can download the manual from the website of the manufacturer. That's probably the smart move. Last thing you want to do is try and do connections without it. That's a quick way to go through more than one.
JD
Digital Advisor
Posted on Dec 01, 2007
SOURCE:
I LOST MY MANUAL AND I CANT HOOK UP MY NEW CASE
Hello.
You can download (and print) the Manual at this site:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=502&DetailName=Feature&MenuID=52&LanID=0
Just click manual, then click USA under the English Manual.
NOTE: You must have Javascript installed on your Internet Browser, and Adobe Acrobat Reader to read PDF files.
Case cables connectors are usually located on the bottom right of the motherboard. (HD LED, PWR LED, PWR SWT, RES SWT, USB, and AC 97').
Hope that Helps.
Jan 29, 2010 | EliteGroup nForce3-A Motherboard
My pc is making a alarm tone sporadiclly and will sometimes shutdown and reboot.I found that by wiggling the harness of wires inside ,the tone alarm will stop..but will start again . Any idea? MB ...
That tone is a warning code.Go to the manufacture websight and look for error tones or codes.
take side cover off and secure all wires and make sure everything is plugged in correctly.
Jan 06, 2010 | R.A.M. Computers Gigabyte GA-K8NS...
I lost my motherboard driver
Check this site for your drivers
http://www.asrock.com/mb/download.asp?Model=K8Upgrade-NF3&s=754
Jun 20, 2009 | Asrock K8UPGRADE-NF3 Socket754/nForce3...
I have an MSI Motherboard 845E MAX and i lost it`s manual, and i have recently disconnected it`s LEDs and the onboard power switch wire, and i cannot remember the way they were, so the motherboard doesnt...
Hai,
There is a Small Written word will be there on a mother board where you have removed the wires please check that and connect it ok it'l work.
Jan 08, 2009 | Computers & Internet
NFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | EliteGroup nForce3-A Motherboard
Where are the EliteGroup nForce3-A power & reset plug-ins located at?
Goto page 10 in your user manual. There look for. Connect the case switches and indicator LEDs to the SW1. (Location).
There is mother board layout decription for how to connect the case, 2-pin wires case connectors ( Page 12 shows pin numbers & which is plus + & negative - pins.). You'll nee the manual to help you. Download it from ECS at: http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=579&DetailName=Manual&MenuID=48&LanID=0
Mike
Aug 12, 2008 | EliteGroup nForce3-A Motherboard
Nforse3-A ver 1.0a 400DDR motherboard
Just click on this link, then you will get a picture of the jumper setup for the power switch, reset switch & the hard drive & power leds where it says SW1.
<a href="http://s182.photobucket.com/albums/x23/partywithjim/?action=view&current=NFORCE3-A.jpg" target="_blank"><img src="http://i182.photobucket.com/albums/x23/partywithjim/NFORCE3-A.jpg" border="0" alt="NFORCE3-A_motherboard_layout"></a>
Nov 17, 2007 | EliteGroup nForce3-A Motherboard
EliteGroup nForce3-A Motherboard Logo
1,778 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
