Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Power Button Blinking Red
Hello, On my PT-50DL54 there is no picture and the power button is blinking red nine times in a row, then stopping for a brief time, then blinking red again nine times in a row. I believe the number of times it blinks is important, helps one know what's wrong with the set. Can you help me? Best, James, Speckarin@mac.com
  • 1 more comment
  • rm789 Jun 03, 2008
    I have Panasonic PT-47WX54 and the power red light blinks 5 times in a row and stops and does the same thing again and again.
  • CHUSH77 Mar 31, 2009
    TROUBLE CODE 1 LOAD SHORTAGE WHERE SHOULD I START DIAGNOSIS PANASONIC REAR PROJECTION 2003 56"
  • Anonymous Apr 07, 2009
    greeting...i have a panasonic PT-50DL54 with a blinking red power light. it blinks 8 times....what exactly does that error code mean?
  • 934 Answers
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
If I can help any other way just let me know...
Good Luck!
Bill
Posted on Dec 01, 2007
    New Friend:
My Panasonic will not power on, and the power button is doing 8 red flashes at a time. So according to the info above the problem is: 8 ' Gc3i-Iic. What does that mean???
Posted on Mar 24, 2013
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
Blinking red power button
How many times does the power indicator blink as thats a error code indicating which circuit has the problem.
Jun 01, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Power 5 time blinks
The blinking code means something is wrong with some components.
It is usually caused by over heating compenents.
Remove the back panel and blow out all the dust using compressed air.
Then vacuum.
May 17, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Power - Red light
You need to open the TV and use compressed air to blow out all the dust from the components.
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
PT54DL50
There is a problem in your 3.3v main line and until corrected it will not power the lamp. This isn't usually an expensive repair but one that a shop will need to do since most of the work will be in trace testing voltage and signal using a scope.
For future information only here are the blink codes for this unit:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
Hope this helps!
Bill
Sep 13, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
724 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
