Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Have mitsu model # ws-65813 wont turn on
Have harmony 880 remote 1 touch sat reciever stereo reciever and tv all come on at once when i pushed 1 touch all came on except tv the green timer light only came on and blinking fast for over 1 day now did this 3 times in last 3 weeks but tv eventually came on but not this time that is connected to surge protect tv never did this b4 i got harmony remote can someone help
Same thing, I tried to turn the tv on and the green light came on but the tv was black then the light started blinking. It would go off for a few seconds then start blinking again. I tried pulling the plug for a while but when I plugged it back in it started blinking again. I tried the reset button but now it won't stop blinking, it's been blinking for 3 hours.
  • 934 Answers
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Posted on Dec 01, 2007
  • dogbutts83 Jun 30, 2011
    had the same problem. wouldnt turn on for days. tried the reset button. would blink green for 1 min. and then try the power button, nothing.even unplugged it, plugged back in and try to power on, nothin push reset button, blink for 1 min nothing. 4 days later: after 4 days of not touching the power button. unplugged the cord and plugged back in. green light blinked for 1 min. i pushed power button and the damn thing turns on!. i dont get it. should i keep it on until i move into another house?
  • William Rayburn
    William Rayburn Jun 30, 2011
    Don't do that just get it repaired... It's not that expensive and if you continue to run it you'll eventually short-out the DM supply and to replace the DM you might as well throw the Tv away...
Setting up my Harmony 880 to work with My Sharp Aqous TV and LG 3400 DVD player - I gt no picture or sound
Begin the Setup Process
Step 1: Create your Harmony Login
If the Harmony remote web site is not automatically launched, go to the Harmony remote web site and
create an account.
Step 2: Complete the Online Setup Process
Once you have created your Harmony login, the online setup process begins. You will guided through a
series of question-and-answer steps to complete each of the five main steps of the online setup process:
1. Identification: Requires you to create a login on our member web site.
2. Check Connection: Ensures your computer and your Harmony remote are communicating
properly.
3. Set up Devices: Helps you set up a description of your personal home theater system.
4. Set up Activities: Helps you set up a description of the connections for devices that allow you to
perform Activities (e.g. Watch Television Activity).
5. Update Remote: Updates your remote with your personal configuration.
Jul 09, 2012 | Logitech Harmony 880 LCD Remote Control
Changes to fios and have motorola 7100 program my harmony 880?
If you have changed your hardware setup, you must reprogram your Harmony 880 using the Logitech software. You should be able to simply step through the 'interview-like' process and enter the new make and model number of the new hardware. It is usually recommended to add the new device first and then associate the new device with your existing Activities. Once your Activities have been mapped to use the new device, you can delete the old one. Once everything has been completed in the software, update your remote through the USB connection. Hope this helped!
Jan 12, 2010 | Logitech Harmony 880 Universal Remote...
I have a Harmony 880 remote and I just bought a Daytek 42" LCD that I got with no remote. How do I get my Harmony to recognize and use my TV?
I am sure you probably resolved thins one by now, but just in case or for anybody else. Load the Logitech Harmony software into your computer. Once you log in, select add device. Select type of device, manufacturer, model, etc. and I am confident it will be found.
I have some really odd equipment and it found all of them.
Dec 28, 2009 | Logitech Harmony 880 LCD Remote Control
Where is the place to open the battery?
Number 1, there are 2 versions of the Logitech 880 Harmony:
You have either the (standard) 880 Harmony, or
the (PRO) 880 Harmony.
Number 2, BOTH versions require a BASE UNIT to RECHARGE the batteries.
I have located the user manual for the standard model here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=36tFryOj&p_li=&p_accessibility=&p_redirect=&p_tbl=9&p_id=5135&p_created=1152806515&p_olh=0
Alternately, the user manual for the "PRO" model is located here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=ZaqdtyOj&p_li=&p_accessibility=&p_redirect=&p_file_id=325891&p_tbl=9&p_id=3693&p_created=1208548871&p_olh=0
Hope this helps!
Dec 03, 2009 | Logitech Harmony 880 LCD Remote Control
Harmony 880 remote will not turn on my dish 622 satellite receiv
Have you tried contacting your dish people, maybe they can reset.
Mar 07, 2009 | Logitech Harmony 880 LCD Remote Control
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
Infrared signal connects to tv etc but then dies
If the infared reciever on the reciever is that bad you might consider getting a Infared repeater (look on ebay, they are like $50. they work pretty well
Feb 06, 2009 | Kenwood VR-309
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
297 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
