Question about Mitsubishi WS-65869 65" Rear Projection Television
Green light flashing
Power surge caused tv to go off and when power came back on the green light was flashing
  • sam7701 Feb 11, 2008
    had a power surge last night, knocking out the power for 2 hours, after restoring the power my 55 in tv flashing timer light wouldn't go off, and the tv want come on.
  • 979 Answers
Unplug the set one more time for 2 minutes then try again. If that doesn't do it, call in the power supply folks....accordianman
Posted on Feb 27, 2008
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
TV turns itself off and power light flashes green
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green light keeps blinking will not turn on at all
May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My tv does not come on.A green light is flashing above my timer button. No picture.
The green light flashing is an error code. Count the number of flashes and it will tell the issue. Write back once you've counted the flashes. Also, was the TV having any issues before this? Was there a recent storm or power surge?
Oct 20, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Wd-62725 green light flashing continuously and TV will not Power
just happened to us, we unplugged in from the surge protector and plugged it in the regular wall outlet and were able to get the tv to come on, don't know why, but it worked
Apr 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Same Green Light flashing!
The timer light flashing usually means that the bulb needs to be replaced.
Jul 25, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
