Question about Toshiba MD20F51 20 in. TV/DVD Combo
Power problem TV turns off for no reason-can't get the power to stay on. Worked fine yesterday and the previous two years.
  • 934 Answers
A common failure in these units is Q401, Toshiba p/n# Bz510004 is a 2SA1624 (HV amplifier) which finally fails due to a resistor R408 Toshiba p/n# Bz210285 a .47 ohm/1w metal oxide having changed in value and at last opening...
This isn't an expensive repair for a qualified shop - but I would suggest not continuing to test your shutdown circuit. What's happening is that HV (high Voltage) is builds beyond tolerances and the shutdown circuit turns your unit off to keep from causing any severe damage. If it failed you could likely burn out the SMPS or cause some substantial damage..
Good Luck!
Posted on Dec 01, 2007
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have a 2 yr old vizio flat panel tv that gets no picture or sound when turned on. it worked fine yesterday but will not come on today. i checked the outlet for power and everything is OK. it reacts like...
Ur power board have capacitors problem,puff up,or burst open capacitors,must replaced these capicitors on the power board.Know how to solders?Or replaced the whole reburbish power board.These website have power,
Jan 11, 2010 | Televison & Video
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Viewsonic not working...
Hello mike this problem could either be that your main board is faulty or the most common problem would be the power supply board which is giving you this problem, what i would suggest just to be on the safe side is for u to do a hard reset on your tv set just incase it is a tv setting problem, disconnect your tv set for a period of 4 hours than plug it back in and see what happens, if that does not work than your problem is more than likely a bad power supply board hope this helps thank you.
Aug 15, 2009 | ViewSonic N3735W 37 in. LCD TV
Tv shuts off after 6-8 seconds
capacitors in the power supply, they all should be replaced, before it takes out the rest of the ps. there are companies that rebuild them if your tech is not up on repairing them.
Jul 23, 2009 | Emerson EWL20D6 Television
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
Sep 28, 2008 | Televison & Video
32 in ilo tv not turning on
The power supply most likely failed on your TV.
I service these power supplies.
Let me know if you need further assistance. my email is
May 20, 2008 | iLO 3200 32 in. LCD Television
Toshiba MD20F51 20 in. TV/DVD Combo Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
