Question about Nikon COOLPIX L3 Digital Camera
My camera wont turn on
I have a Nikon coolpix L3, changed batteries, worked for a few days, then wouldn't turn on. Changed batteries again , but it won't turn on!
Thank You
    Scholar:
  • 48 Answers
First thing I would look at are your batteries. Chances are, you may be using batteries which aren't recommended for your camera. Use alkalines at least. Even better, batteries with a higher mAh - like around 2500mAh would satisfy the higher power requirements of your camera.
Another option is to reset your camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Nikon's website and look for firmware updates. Download and install them.
Posted on Dec 01, 2007
SOURCE:
How can i open the battery door of nikon coolpix l3
Most camera battery compartments have "raised lines" on the cover. They usually suggest that you put your finger or thumb on that surface and push with a sliding motion to open the cover. Again, there are many different models, but the Coolpix I have seen have that kind of opening device. Hope this helps!
Nov 29, 2014 | Nikon COOLPIX L3 Digital Camera
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
I have a Nikon Coolpix L3. A couple of days ago, I noticed that My camera was on, And the lens was out. I tried turning the camera off, but the lens wont go back in. I tried Wiggling the lens, Tried...
a lot of camera seem to be having this problem. keep trying to turn counter clock wise. but do not force it keep wigging back and forth it will go it just gear driving. and problem got hun up do this with the camera onand then try it with it off
Mar 05, 2009 | Nikon COOLPIX L3 Digital Camera
LENS ERROR ON COOLPIX L3 CAMERA
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Nikon Coolpix S210 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Dropped my coolpix L3 in the water
Probably no fix possible. If it was salt water, it is done. If it was normal clean water, you may still have a slight chance to get it going. Remove the batteries, and let it sit on a shelf for a couple weeks, that is to let it dry. Then put in the batteries and see what happens. You soon will know.If you have the patience, it may be better to take the back cover off, making a note of where the screws came from, to remember when putting together. Then let it dry for a few days.
Mar 09, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix L3 thinks batteries are dead
I think this was a firmware fault on some cameras. Check with Nikon to see if there is a new firmware for your particular camera. This can be downloaded free of charge and uploaded to the camera via USB.
Jan 04, 2008 | Nikon COOLPIX L3 Digital Camera
Batteries die
Hello; Same as tbeartusk on my coolpix L3 Nikon
Batts exhausted within 30 Min. and screen says Batteries "exhausted"
Nov 12, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
177 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
