Question about Samsung SCX-5115 Fax Machines
Will not print due to OPEN HEAT ERROR message?
The machine will not function due to OPEN HEAT MESSAGE? Please advice whether the cost to repair is less than purchasing a new machine?
  • 1,113 Answers
Will need to have fuser replaced, guestimation is 150-200 for fuser plus 50-100 to fit
Posted on Dec 01, 2007
Canon mx922 error message needs repair
It is likely that the print-head temperature sensor is detecting an over heat. If that is the case, start thinking about a replacement machine as the printheads are expensive to replace.
Feb 22, 2015 | Canon PIXMA MX922 Inkjet Multifunction...
Thank you for your message : I have printed the page 3-92 and read the manuel but I am afraid I am not able to do the operation : "check connector P/J18 on the MCU Board ": I don't know what it is ? W
Marmier, Do you know who did send this message? Looks like you got a message from Xerox support. To check you connector, you need to open the Printer / Copier. Not something I would advice, if you don't have the repair manual and not the skills you need to repair electronic equipment.
If Xerox did send you the message, please contact Xerox again. If someone on foxy did answer, sorry I did react on this one.
Nov 04, 2014 | Xerox 6015VB 6015V B Copy/Print/Colour...
Samsung Triflow SW80ASP washing machine not rinsing or spinning cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. In this case it is important to check for the heat on the drain valve/pump, the motor and the inlet valve as this is a possibility that the heating produces the smell in which case it must be replaced.
For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Apr 09, 2012 | Washing Machines
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
What does red light means when I turn the xbox 360 on
you xbox is overheated to fix it Call 1-800-4MY-XBOX and listen for Hardware>Red Lights
Sep 02, 2010 | Microsoft Xbox 360 Console
Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
Why Am I getting the error 41 message?How can I fix it. Can I fix it myself?
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Nov 11, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Samsung SCX-5115 Fax Machines Logo
140 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
