Question about Motorola Mobility SLVR L7 Cellular Phone
Charging Socket Do Not Connet Charger Connecter For Charging My Mobile
    Brigadier General:
  • 7,752 Answers
Have the charging connectot replaced
Posted on Feb 15, 2008
SOURCE:
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
Can i get a new mains charger for my 8i0i?
Please try it My Dear Brother:
First Option:
Second Option:
Dec 05, 2012 | Sony Ericsson Walkman W810i Cellular Phone
I am using sony ericsson z550i it is not getting charge can u plzzz give me a solution
Dear,
first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil.
then see if it works,
if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging!
try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger,
its time to buy a new charger.
original charges cost=900
duplicate charges cost=100
regards!
Aug 17, 2011 | Sony Ericsson Z550i Cellular Phone
Not charging even on changing new connecter/battery/charger which are working with other mobile
if you can open the phone,check the charging pin if it is ok,check the interface.
otherwise..hardware problem... better bring it a service center
May 31, 2011 | Nokia 3110 Cellular Phone
Nokia 3110c Charger not supported
First Option:
Second Option:
Dec 29, 2010 | Nokia 3110 Cellular Phone
Please help my nokia 2626 charger not support problem
First Option:
Secend Option:
Jul 13, 2010 | Nokia 2626 Mobile Phone
Mobile is not charging relince cdma f309
Sunil, There could be a number of reasons for your mobile not charging. 1. The battery charger could be bad. Get a new one. But before that try on a different phone or with a multimeter if it has some output. 2. The battery could be absolute dead. With a multimeter check it for some output. And also try to charge it with a different charger. These days I have seen different types of chargers at big stores for the public to charge their mobiles while shopping. try to charge from there. If the battery is dead then it need to be replaced. 3. The mobile charging socket could be bad and not connecting to the charger plug. If you have the required tools, then you can open the mobile and replace the socket. 4. The charging circuit of the mobile could have gone bad. needs special tools and knowledge to rectify the defect. If you feel faint doing it then visit the nearest service center (specially if the phone is under warranty).
Nov 21, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Sir, charging problem
it is the problem of charging socket problem
Oct 23, 2009 | Nokia 2626 Mobile Phone
My charger is not fitting the phone, seems a hardware problem with the charging socket in the phone. Can the socket where the charger is connected be replaced/repaired?
you should chage the charger and buy right charger for long life of your mobile... dont use alternate...it will harm your mobile
Apr 27, 2009 | Nokia N72 Cellular Phone
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
