Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose lifestyle model 5 music center
Hi I plugged in a power supply (from different unit different plug) into the system controll port. Unit works, cd plays, i hooked up to a different amplifier music plays, when you connect to original amplifier the amp does not come on. I opened up the unit, two resistors inline with this port are blown (can't read the value of resistor) I need a schematic. I have background on servicing units just don't have access to service manuals
  • 2 more comments
  • junkin Dec 02, 2007
    sound comes and goes while on surround sound during movies cd player radio etc... we have checked all connections. we have turned device off and unplugged in order to reset. still the problem continues.
  • Anonymous Dec 18, 2007
    radio and everthing dead,nothing,fuse was blown in power supply,replaces ,still nothing,no lights,no sound,no cd need wiring diagrams
  • boatdriver Feb 19, 2008
    I am having the identical problem and appears the Acoustimass is shorted out...however I do not know how to OPEN THE UNIT.Please advise so that I can at least identify the problem and maybe get the same feedback from
    myszka.
  • Anonymous Dec 19, 2008
    I am also searching for the same pin conection . but for the time beeing i have conected pin 1and 2 for steereo input ,ground to outer sheild . it is working alright .
    My remote is not working please guide me how to reset the remote.
    my mail; peterongc@yahoo.com
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Posted on Aug 02, 2008
CHECK A OTHER SYSTEM
Posted on Dec 01, 2007
Is there any adapter to use the 9 pin flat ribbon system control cord on other systems.
You posted in the category 'Laptops'. You want to power a CD Player unit out of a computer to run from mains power?
The flat ribbon cable is the data cable, so no.
Power is by a separate lead which supplies 5 volts or 12 volts via the Power Supply Unit.
Jan 05, 2016 | Computers & Internet
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
Our Wii console will not power on and there is a disk in it.
Follow the directions below to see if this helps. If not, you may need to contact Wii technical support for repairs.
power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
Click here to contact Wii support
Regards,
G33k
May 05, 2011 | Nintendo Wii Console
I hooked up my n64 and everything is working perfectly, except it's telling me there's no controller plugged in...when there is. I've tried a different controller, playing with the wires, resetting, using...
Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Jan 21, 2011 | Nintendo 64 Console
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
Does anyone know how to set up an old nintendo game
I am assuming you mean a nintendo entertainment system (NES)
You Need:
The gray master console
At least 1 controller
Power supply
RF Switchbox (Must be an auto switchbox) or an A/V Cable with RCA ends
The power supply & RF switch plug into the back of the grey master unit. Hook the RF switch up to the cable connection on your TV. (If using the A/V cable - it plugs into the side of the master unit & into a video in - yellow plug/audio in - white plug) Plug in the power supply. Make sure a controller is plugged into the 1 outlet on the front. Make sure a game cartridge is inserted & locked in (You push it down). The TV needs to be on whatever channel the switch is set on if using the RF switch (Channel 3 or 4). Turn on the power & it should work
Jan 03, 2010 | Nintendo DS Console
Console light stays green all the time.
Your system's power supply cord could be faulty.
it could be receiving too much current and its making your power supply think the system needs to stay on. try plugging your console into a different outlet or surge protector. if that doesnt work you will most likely have to get a new power supply cable.
Dec 17, 2009 | Nintendo Wii Console
Need manual for lg#lht764
you can hook up yor i pod unit directly into the back of the unit there is a special slot were it plugs into and you can use the remote to operate it once it is hooked up .you can veiw the functions from the tv in ipod mode or you can plug it in from the front lower left oped lid and plug and play
Dec 09, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
Audio electrics
chances are if you got it from ebay there are going to be missin plugs for that unit.....and if i had to guess the two wires would be power (12v) n ground which should be red and black but differs on different cars.
Oct 01, 2008 | Car Audio & Video
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
Bose LifeStyle 5 Series-III CD Shelf System Logo
7,803 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
