Question about Microwave Ovens
Microwave Oven Sharp R820BK Convection Microwave oven. LCD has gone bananas....can't read numbers. What shall I do?
  • Microwave Ovens Master
  • 9,173 Answers
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 01, 2007
SOURCE:
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Display does not show information (words or numbers) when entered or while running. Cannot tell what it is doing, however light, turntable seems to function. Can it be fixed or can the display pad be...
Sharp uses a conductive strip between the display crystal and the circuit board. If you remove the board and pull out the conductive rubber strip, clean it with alcohol or an eraser then re assemble it. it might work Other wise, you have to replace the main circuit board as an assembly. Get your model number and call a parts house called encompass parts. For pricing and availability
Sep 22, 2017 | Sharp R820BK 900 Watts Convection ...
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
Manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Jun 13, 2009 | Sharp R-820B Convection/Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
