Question about Viking VEDV900 Kitchen Hood
Vicking VIDV500 Kitchen Hood
Just bought a home with this island hood, and the fan wont run. We dont have an ops manual. Any trouble shooting tips?
Steve Carrra
  • Anonymous Feb 19, 2009
    Our vent won't go up and the fan doesn't work. Is there a reset button
I have a 36" V600 wall mount hood. Replaced both bulbs and they still won't light. Fan works perfectly. Unit has on and off switch and dimmer switch. Any suggestions?
Thak you, Mike
Posted on Dec 01, 2008
  • 833 Answers
Steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Posted on Dec 09, 2007
SOURCE:
How to clean my downdraft VIDV500
take a damp wash cloth or rag and get up under there and SCRUB
Sep 03, 2013 | Viking VWH3048 Kitchen Hood
Iam going to buy the the DA5000 miele island hood can not find any reviews on it ? has anybodt bought this before?
I have not bought this hood,yet im falmliar with Miele appliances and have found them to be the cream of the crop,its hard to beat the German engineering and among the top German brands. Miele/Bosch/Gaggenau Meile is the best, its like cars a BMW is a fine car but MERCEDES BENZ is so much better,in my oponion Meile is the Mercedes of appliances.
Gene
Aug 05, 2011 | Miele DA 5000 D 43" Kitchen Hood
My 1999 mazda 626 6 cylinder overheats if traffic slows down for very long, stop for a train, etc. At other times the air coming out of the vents is very cold. I have added coolant several times.
Your radiator fan is probably failed. Pop open hood, watch temp rise, once past "normal " level teh fan should turn on. If not, you need to trouble shoot the rad fan. There should be heavy duty fuses and relays under the hood in an electrical distribution box. You should consult the owners manual or chart on the box lid. Of course the fan maybe bad itself. You can also try - turn on the AC, this will activate the 2nd (booster) fan, and should help prevent serious overheating but wont fix the underlying problem.
Good luck
Jul 13, 2011 | 1999 Mazda 626
Problem with cooker hood
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Mar 09, 2010 | Rangemaster Kitchen Hood
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Installing a vent hood...
There is no kit to make this conversion. That being said, you could get an estimate from a sheet metal fabrication shop on creating the conversion you are seeking.
Good luck with it.
Feb 13, 2009 | Frigidaire PLHV36W7CC Kitchen Hood
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Kitchen Ranges Logo
530 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Steve Allison
Steve Allison
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
