HI, WHAT IS THE CONTENT OF THE CD. IS THIS A MUSIC CD? IF IT IS , ALL YOU NEED IS A SOFTWARE LIKE WINDOW PLAYER OR ITUNE TO PLAY THE MUSIC. YOUR WINDOW PLAYER MAY NOT BE SET UP AS AN AUTOMATIC TO PLAY YOUR CD. OR YOU LOST OR THE SOUND DRIVER IS DE ACTIVATED. YOU CAN CHECK THE SOUND VOLUME FIRST, OR CLICK START, CONTROL PANEL, CLICK THE SOUND DEVICE AND CLICK THE HARDWARE TAB AND CLICK THE WHAT KIND OF SOUND DEVICE RIGHT CLICK AND THE PROPERTY WILL APPEAR CLICK THE UP DATE DRIVER AND FOLLOW THE COMPUTER INSTRUCTION. HOPE THIS INFO WILL HELP YOU SOLVE YOUR D & E DRIVE PROBLEM.
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the...
(More)
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the abit shadow card for the PCIXP2 slot. Where can I get this?
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card...
(More)
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card reader is dead. formatted and reinstalled windows xp hone on new hdd. can now use rear usb devices but still intermittent crashes. what do you suggest. I suspect moard fault. I would rather get a new moard with better specs, and use existing, very good, hardware. What m-atx board would you recommend. Thanks in advance, Paddy.
