Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
PT54DL50 Woke up truned on no picture power button blinlking 3 red blinks? replaced lamp....needed it anyway. Stilll 3 red blinks? Help Chip I have the same problem.........was working great, turned off for the night, next day turned on, and all I get is the red LED flashes 3 times, stops for 60 seconds or so then flashes 3 times, continues this cycle over & over. I unplug the TV for a while (LED stops flashing), then plug it in, turn it on and the green light comes on like a normal startup, then it reverts to the 3 flashing LED cycle again. The user manual (for flashing red LED) says call service center, but I live in Hawaii, and the closest service department is on another island. Help!!!!
  • Panasonic Master
  • 1,113 Answers
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Posted on Dec 01, 2007
SOURCE:
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
PT-.. NO POWER NO SOUND
yes if the lamp doesnt light the set cant complete the boot sequence. replace the lamp and your set should be fine.
Apr 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony wega problem look like im not the only one!
This sounds like your lamp failed and opened you thermal fuse. 6 blinks is open thermal fuse and that would normally only open if your lamp failed. Replacing the lamp is simple, but the thermal fuse is a very difficult repair with considerable disassembly.
Mar 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Nov 10, 2007 | Sony KDS55A2000 55" HDTV
PT54DL50
There is a problem in your 3.3v main line and until corrected it will not power the lamp. This isn't usually an expensive repair but one that a shop will need to do since most of the work will be in trace testing voltage and signal using a scope.
For future information only here are the blink codes for this unit:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
Hope this helps!
Bill
Sep 13, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
257 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
