How to test 5v ic regulator(3 pins)
Greetings Sir
Please help me how to test the 3 pins voltage regulator using  the VOM,i have no other spare parts to base-on..
Thank you..
Francis
  • sdnizamud Mar 02, 2009
    Is there any way you can test KIA7805 out side with just multimeter, because in some equipment the regulator IC are installed in such a place that you can't test the voltages with the probe. my email address is [email protected]. If anyone knows how to test regulator IC with normal multimeter just guide me.
  • Dave Dec 07, 2012
    Try this link it might help http://www.learningaboutelectronics.com/...
Most chips are as follows pin 1 input voltage pin 2 common gnd pin 3 volts out ie 5vdc connect vom meter to it as follows black lead to middle pin red to pin in right if you can read the print on the chip set vom to vols dc and check it
Posted on Dec 03, 2007
    Novelist:
    Champion:
  • 232 Answers
Francis, 3 pin voltage regulators have the following;
1 pin is INPUT, let`s say 12 volts
1 pin is OUTPUT, let`s say 5 volts
1 pin is GROUND, all electronics equip. has to have a ground
the problem is they are not all wired internally the same so how do you tell which is input pin and which is output pin ? the best way to find this info is find the data sheet on-line. Google the letters NTE and click on their cross reference link and then enter the number on the front of your regulator and it will cross your device to NTE`s device and show you the info, hope this helps you, Happy Holidays BMW Rider
Posted on Dec 01, 2007
SOURCE:
Needles on my Gauges are absolutely crazy! 1996 Pontiac Grand Am SE V6
1= this happen because th IVR fail, see the diagram and test it use the DVOM OR VOM for test the IC .l
2= test the thermistor or sensor for defective.
3= if the voltage of IVR is out of regulation in this case +12vdc,test for ground.if is o.k test by the side of battery side of the IVR, if this voltage is present replace the IVR, if regulated voltage is withing specifications, test the printed circuite from the IVR to the gaues, and if there are open circuite replace the circuit board. OF course test the fuse too.
God bless you
Jul 14, 2012 | Cars & Trucks
RCA projection TV #D52W15B 52inch Jan2004 bought mid to end of year. (D52W15BYX1) HDTV/monitor Watching a channel clear and normal went to another channel all blurry..same on all channels. Tried DVD...
Hi the problem you are having is going to be with the convergance ic they will need replacing this is a common problem with this type of tv and tv repair shops are familiar with this type of repair but getting this done will solve your problem and should last a good 2 to 4 years after repair has been done
Mar 26, 2008 | Televison & Video
Tip
How to measure the voltage on TV
Voltage measured on DC scale, black cable multitester / avometer put on a negative path or can be slipped on the silver wire in the tube that is not disposable wrapping.
Next, measure the voltages are available:
  • For 180v voltage can be measured on the positive pin elco (10uf/250v) in PCB RGB tube.stick pin red wire multitester
  • Voltage 110v for TVs 14 "-21" and 130v for 25 "-29" in the B + FlyBack Transformer (FBT), find the path there is elco 100uf/160volt. measure on a positive foot elco.
  • For 12volt voltage, please measure at the foot of the right edge of IC 7812.
  1. For voltage 5V, please measure the right foot of IC 7805.
  2. For voltage 33v, please search at the foot of VT in tuner.
  3. To measure 90v-300v, scale use DCV 250.
  4. To measure the 12v-40v, use a scale of 50 DCV
  5. To measure the voltage of 1V-9v, 10 DCV-scale use.
  6. How to measure the voltage on the yoke and in plyback is;
    • From the yoke horizontal = Fcc 110v DC, 1000 V. AC voltage can be removed with a red plug in output and in use as dB meter.
    • From the yoke pertikal 24 DC current model, except for disposable coupling C = 1 / 2 Fcc. While it could be IC 120V AC (with dB meter)
    • At Fcc FBT kolector; 110v DC, AC voltage = 1000 V..
    • At Fcc FBT filement / heater = 5V-5, 5V AC.
    • In the FBT 20-32k anode voltage V measured with 40kv HV probe is added to the multitester 1000 V. DC.
    • Voltage others depending on model and type of TV. 180v out there (for RGB) directly from the regulators, transformers, Video Amp taken from FBT.
    • There are 24V and 46v vertical FBT, also 12-18V depending on brand and type.
    • Voltage 600 V DC and focus around the screen 400v DC.
    Thus tip n trick from me (AGUS YUSTIARA ), hopefully useful.
for more info , at http://trend2download.blogspot.com
on Aug 16, 2010 | Televison & Video
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Apr 30, 2011 | Sharp LC40E77U LCD TV
How to make regulated power supply
The easiest way to do this is to use a 3 pin regulator IC.
For a 5 volt supply go to this WEB site,
http://schematicwiring.com/simple-electronic-applications/5v-dc-regulator-with-3-pin-regulator-circuit-schematic-diagram/
For a variable voltage power supply go to this WEB site.
http://www.engineeringslash.com/power-supply/three-terminal-adjustable-regulator.html
Mar 16, 2011 | Computers & Internet
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Samsung CRT Blank Screen
1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
2. check 5V supply,change 5v Regulator.
Aug 19, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Unit shut off after 15-20 minutes
The problem is IC 451, (Yamaha Part # XU814A00) (Number on part PQ05RD11 Made by Sharp). It's a + 5V 1A Voltage Regulator.
It's located at the bottom of the power supply board mounted to the front heat sink. It's a four legged TO220 Package outline. So don't try to slip a three legged 5 volt regulator in it's place. This can cause serious damage and headaches. Change this part and everything should be good.
Nov 15, 2007 | Yamaha RX-Z1 Receiver
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
Televison & Video Logo
4,152 people viewed this question
Top Televison & Video Experts
Ekse
