posted by joeh9222003 on Dec 01, 2007
I dropped it when i was installing it, and now i have a dark (darkened and discolored) square right in the center.. now the lamp is not broken and everything is still operational
Solution #1
posted on Mar 25, 2008
Hi there
It sounds like you have a damaged Packlight Pipe Module.
Very cheap part to have replaced.
Easiest way to check is to switch on the unit and tilt it from side to side - if the darkened bits move , you can count on it that this is your problem.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for BenQ MP610 Multimedia Projector
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
NEC LT170 projector won't turn...
Why won't my projector turn on... Answer This...
Shutting off Filter Cleaning...
I vacuumed all the filters on... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
