Question about HP Pavilion dv1000 Notebook
Hp pavillion 2120 screen has gone black
I have problems with hp pavillion 2120 screen. This machine as very few hours if use, yet it's screen has gone to balck. Every once in a while you could see the desktop in a shadowy kind of way. there also appears to be no sound, although it was muted when the problem occured. What do I do??
Nana Slug
  • 3 more comments
  • Anonymous Dec 11, 2007
    my computer went to hibernation mode and turned off now it wont turn on
  • jamilsilva Dec 31, 2007
    I have the same problem. I do not know what to do and would apreciate some helpful information. I also tried the to connect the video output to a lcd external monitor and the problem persisted.
  • soniacanales Apr 06, 2008
    mi PC HP pavilión dv 2120 LA por accidente entró en hibernacion y no se como sacarlo de ese estado ,por el momento funciona la Multimedia
    les agradezco ayudarme . gracias
  • jhimroe May 10, 2008
    hp pavilion dv1000 has gone b,ack
  • Anonymous May 13, 2008
    My screen has gone black 3 times in the 14 months I've had this computer. It is currently in the "shop" for the third time and has been in the process of being fixed for 7 weeks so far. What do I do as a college student with no computer for almost 2 months?
    New Friend:
    Problem Solver:
  • 12 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
I have HCL9200lx model have similar problem can able to see screen but not completely barely able to see the screen nd booting is proper
Posted on Oct 07, 2008
Just got this problem , I plug out the battery , put on AC and start it , it did boot up well , I have to see now when this will happen again
Posted on Sep 25, 2008
This is so common that hp will fix it for free even after warrenty expires call 1-800-hpinvent they fixed my laptop in 3 days free shiping even
Posted on Apr 16, 2008
I have had this problem with my desk top HP monitor twice a few years ago and HP fixed it even though it was out of warranty. Now it is happening to my lap top, I now beleive that this is a problem HP with there units.
Posted on Jan 23, 2008
  • 31 Answers
It may be that the brightness of your monitor is turned all the way down. In the lower left of your keyboard, there is a "FN" key between the windows logo key and the left ctrl key. Hold this fn key down and continually press F8 until the screen brightens up.
Hopefully this helps, keep us posted!
Posted on Dec 10, 2007
Hi folks I had a similar problem to the 3rd one in which the lights would come on but the screen stayed Black. I searched aroud some HP sites and found a suggestion on reseating the RAM. It worked and takes 5 minutes. Remove all power sources. Remove the cover on the back just below where the Battery goes it has 2 screws. Remove the cover. This exposes the Ram. Mine has 2 sticks one on top of the other slightly overlapped. Each is held in place by 2 small metal tabs pull gently on these an the Ram stick will pop up and you can easily remove it from it's slot. Remove all of it and then reverse the procedure and reinstall it. It takes 5 minutes and mine booted up right away.
Posted on Feb 28, 2008
SOURCE:
My hp Pavillion dv6 laptop can no longer use Constant Guard which Comcast supplies. Also Quattro Pro quit working midstream. How do I fix it?
More then likely running System Tuneup replaced critical files that Comcast Constant Guard and Quattro Pro uses... I recommend doing the following three steps but only if you have the Original or backup copies of the installation disc/media for both applications: 1) uninstalling the Comcast Constant Guard application 2) then do a normal shutdown and reboot once it has rebooted 3) install the Comcast Constant Guard once that's done and successfully do the same three steps but for the Quattro Pro application
Jan 02, 2015 | HP Pavilion Computers & Internet
HP Pavillion dv2 1005ee booting Problem
Microsoft me id kese banti he....
Nov 10, 2013 | Computers & Internet
My screen on my hp pavillion dv 2000 begins to fade....goes white
You have a loose connection on the cable for the screen. The case of the laptop must be removed and the cable reseated in its connector and the problem will be gone.
Jul 09, 2010 | HP Pavilion dv2000t Notebook
HP pavillion entertainment PC has blank screen. I
Hi there from reading your whats you wrote this tell's me that your computer screen has gone bad. Because you are using a laptop you cannot change the graphic card,for you to solve this problem you need to change the screen.
May 19, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
Hp pavillion wont boot, i just get a black screen
hello
I have read your problem and I think its a sure case of gone RAM.
Replace the RAM with a new one and your system will work fine.
Thank You
Jul 11, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion DV9000
Howdy,
Like you said if you purchase it 5 month ago it should still be under the warranty. if i were you i will go that route
Dec 30, 2008 | HP Pavilion dv9000z Notebook
HP Pavillion Laptop
I have just experienced same p[roblem with my Pavillion laptop. Seems to be a graphics card problem. (Hp have issued extended warranties to cover this problem, which is apparently quite common in the pavillion range?)
I have had to send my machine back to HP to fix it. gah.
Aug 20, 2008 | Computers & Internet
HP Pavillion dv2000
well, try hooking it up to an other screen and see if it boots up,if it does your screen has taken a flop if it doesn't your viedo card is gone. lala linda
Jun 03, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
1,116 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
