Question about George Foreman GRP4P Indoor Grill
Uneven cooking The top grill does not cook evenly with the bottom. What can I do??I don't have the receipt to return it with.. If I can't get is so it will cook even I will send it to you..
  • Elden Dec 30, 2007
    Uneven heat. Bottom hotter than top.Is this normal?
    I have only used it 3 times
    !st Steak. Bottom over done.
    2nd Italian sausage Top just right bottom burnt.
    3rd Portobello Mushroom. I watched it very closely. Turned it and it was fine.Total automation has not yet arrived. It still requires close attention.
  • 368 Answers
Hi pcarter21,
I'd contact the manufacturer (Salton, Inc.) customer servicesite for replacement parts or manual. If they don't have them, they should knowwhere to send you (though if they don't, I'd seriously wonder about thecompany).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 31, 2008
Traeger has uneven heat on grill, some areas burn others under cook
The Traeger has hot spots like any other grill, especially in the front and back where the grease pan doesn't cover and over the heat box. You have to move food around or put your thicker pieces over the hot spots.
If it's getting really hot, you probably have grease in the bottom that's catching on fire. Be sure to clean it out regularly.
Oct 18, 2017 | Grilling
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
I put the charcoal in the bottom bowl in the smoker. what do u put in the top bowl right above that? i am making beef jerkey
Hi there....the top bowl which is smaller than the charcoal bowl is primarily for water to keep moisture in the roasting environment while cooking..I don't think you want to add miosture to make jerky...I have a Ronco food dehydrator for that...I only use my smoker for slow cooking and roasting/smoking large peices of meat..I hope this was helpful.....
Sep 05, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
How do I get best results with the weber BBQ as far as heat efficiency
You can actually get some good cooking tips at the weber on-line site. That said, you really don't want to concentrate on efficiency but rather on the type of food you are cooking. I always used to stack the brickets in the beginning to get them lit and graying and then spread them for an even heat to enable cooking on all of the grill surface. If you need more concentrated heat from below then leave them stacked or in a bricket rack.
Jul 22, 2011 | Weber One Touch Silver Charcoal Grill
The cooking is not even when cooking small items
Often times this isn't something you want to attempt to rectify yourself. If you can find a way to deal with or adjust to this issue it will save you the cost of a repair visit. If the uneven bake is so severe that you cannot cook in the oven and you still wish to attempt repair by yourself you first need to identify which racks aren't cooking correctly and in which pattern is it uneven.
For example is the rack uneven in overall color from top to bottom, meaning are items on the top cooking to quickly where as the items on the bottom are uncooked? Or is the uneveness lateral where the center of a single tray is over/under cooking or the edges of a tray are over/under cooking.
Once you've identified your issues you need to locate your airflow louvers. They are usually located in the back right corner of this oven, it is where the hot air comes out of the heat exchanger chamber. You will notice there are gaps and there are fins. Adjusting the fins changes the way the air flows from side to side across your product, adjusting the gap changes how much hot air reaches the product.
Lets approach side to side uneveness first. To compensate for the center of a tray UNDER cooking take the metal fin lined up with that tray on the RIGHT side and slightly bend it to the left, directing air towards the center of the tray. If the center is over cooking bend it to the right, directing air away from the center of the tray.
For top to bottom uneveness you will need to loose the screws/bolts holding the fins in place and gently increase or decrease the gaps. Be careful here because if you loosen the screws too much the louver can slide out of place and make to large of a gap, potentially making things much worse. A good trick is to take a permanent marker and make a mark to where the louver was before you adjust it incase you need to put it back.
If a single tray is too light in relation to the other trays increase the gap, if it is too dark, decrease the gap. Do this for each tray that is coming out uneven. Make small adjustments and then do a bake to check the results, there may be a lot of trial and error involved.
If this seems overwhelming you're probably better off not attempting this because you can make things worse to the point where NOTHING comes out correctly, if that's the case call your local authorized service provider. Good luck!
Jan 03, 2011 | Baxter BXA2G Stainless Steel Gas Single...
When cooking do you leave the lid holes open or closed
Somtimes using a charcoal grill can be tricky...are your charcoal briquetts fully lit and ashed over before yo start cooking...if so..the next trick is to get a good "draw" so the grill operates properly...you have to get air in the grill thru the botom vent and out te grill thru the lid vent at just the right rate to get a nice stream of smoke thru the lid vent without flaming up under the food.You have to make sure that you have the bottom vent partially opened to allow air to flow thru...remember air in thru the bottom and out thru the top....also try to use a good quality charcoal such as "Kingsford" because they burn longer than any I've ever used....It's a trial and error thing.....PS....don't try to relight by squirting starter fluid...This is very dangerous.... hope this was helpful..
Oct 31, 2010 | Weber One-Touch Gold 18.5 Grill
Cooking a whole chicken / lamb roast
Good Evening, I love cooking with Charcoal/Wood. The bottom vents will adjust the temp, closed the coals burn slower and cooler. The top vents also control the temp, however more importantly the flavor by keeping the smoke in or out. With a roast you want low heat so I would close the bottom vents 1/2 way or so and since i like a smokey flavor of Hickory would keep the top vents closed. The key to a good Barbeque none the less is slow cooking. It also takes fine tuning, wind, breezes all effect how fast/hot the coals burn. Don't be afraid to add more coals as needed as well. Good Luck and have a great cookout. Thanks for using FixYa. Jeff
Apr 20, 2010 | Weber One-Touch Gold 18.5 Grill
Uneven cooking food has to be turned every 10 minutes, bottom of food burns and top dosent cook
How does the food know which way its facing?
Try covering the food with a lid from a smaller pan.
And always remember...to cook faster, sometimes you have to cook slower! A carbon layer on food acts as a heat shield against further cooking!
Dec 09, 2009 | Baumatic BT2395SS Gas Kitchen Range
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
Poor fitting lid
Most lids on crocks are loose fit due to pressure release that is required in most receipts... read your receipt for example BEAN SOUPS, or LENTILS and you will find that the should be tilted for proper cooking.
Cooking time in a crock is different from stove top or oven cooking... Remember the saying that "Heat cooks and fire burns" ... well, never is this more true than with your new slow cooker. So here are a few examples for you to try:
FIRST RECEIPT: take out some fresh or frozen meat your choice' dice up and onion or simply just cut the onion in 1/2 for easy removal later. I tend to season/salt>>> my pork, lamb , and chicken; however I do season/salt beef if I am only cooking it in water>>> for like tender shredded beef tacos. Anyway set your crock on high in the morning or at night before going to bed
( warning do not leave your crock unattended if you have children under 12 years of age around that might try to serve themselves when the crock is cooking)and don't except to have the children not want to investigate you savory dish>> they might and will get 2nd degree burns from a 215 degree cooking temp.
SECOND RECEIPT>>
Try a 7 or 15 Bean Soup add your smoked turkey or pork ham to the pot with seasoning/salt and an onion. set on high and go to work . When you cook home you and or your family will be delighted to find a wonderful home cooked meal waiting for your taste buds to enjoy!!!
good luck
Jan 08, 2008 | Bravetti KC281HB 8-Quart Slow Cooker
Kitchen Appliances - Others Logo
96 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
