Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU5318: Water wont start washing
My bosch has had problems, first it wouldnt shut off by itself. When it was down to 0 minutes it would start back at 30 mins and continue washing till I manually set it to drain pressing the scrub and delicate buttons simultaneously. The washer started and washed as normal, but when it was time to complete, I manually drained it. This worked for a couple months, then it stopped washing altogether. When starting the wash it turned to 2 H and never started washing and the 2 H never decreased.
I tried the diagnostic, but it never cycles through the wash phase. The lights flash and says 0 in minutes, never completing the diagnostic.
I replaced the control panel and still it wont wash. The wash cycle starts off at 90 min like expected and even counts downward. When it starts, it sound like it drains, but then after that, the water never comes out for the wash. It continues to count down.
I think the machine has had it.
HELP, my wife is gonna kill me if I don't fix this or replace it.
    President:
  • 1,314 Answers
If it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Posted on Dec 30, 2007
BOSCH WASHING MACHINE WONT START BEEPS TWICE
The newer washing machines now have computer like problems. Sometime unplugging the machine for a few minutes then plugging them back may fix it. This could be warning beep related to the door not being shut properly or other issue. You need to find the manual and find out what two beeps mean. If you do not have the manual you probably can download one. Bosch may also have a help line to call for its customers.
Aug 19, 2014 | Washing Machines
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH DISHWASHER RUNNING TOO LONG PROBLEM
Bosch dishwashers are designed to heat the water to temp. However it has a 3 hr default if it doesn't reach temp. Start the cycle and see if after 1 hour if the water is hot or cold. If hot, then it is heating the water and the water coming in is just too cold. You may try running the water at the sink to get it hot there first before starting the dw. If the water is cold, then your unit isn't heating the water. At this point I pull the outer door panel, find the largest wires on the control unit and put my meter leads on them then start the machine. You will see 120 volts on your meter. Start the machine in light washes and with in 10 to 15 minutes you should see 0 voltage. Than means the relay has closed in the control and the hot line of the 120 volts is being sent to the heater. If this never happens, then you have a bad control. Bosch dishwashers have a 5 yr part warranty on the electronic control. Now If you get the 0 volts, I will put my amp meter on one of the same wires and check for 9 to 11amps. If that isn't there, then you have a bad heater assy. Hope this helps
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Aug 02, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
319 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
