SOURCE: Craftsman 10 inch miter saw, handle broke
I would reattach it with epoxy. Go to the hardware store with the handle and let the clerk help you pick out the best epoxy for the job.
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
SOURCE: bearing replacement
Do you have a small bearing puller or a bearing splitter? On some I have had to crush the outer race and then clamp on the inner one and pull it that way. I have also used screwdrivers (GENTLY) to pry the bearing up a little so I could get it with something else. If you have a tool repair shop in your area, generally they would not charge that much to remove and reinstall the bearings for you.
SOURCE: Makita LS1030 miter saw, base doesn't rotate as
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
