You have to pay for xbox live. If you do not pay for xbox live then you cant get the internet for your xbox 360. Its one thing i hate about having an xbox. Hence the reason for me getting the playstation 3. I hope this has helped.
you need to set up an xbox live account. you can either go through ur computer or through ur xbox. then u need to pay for either the gold (1 year) or silver (3 months) membership. and you also need internet access. if ur xbox 360 does not have a built in wifi adapter, you need to connect an ethernet cable to your router in order to get connected.
you need to sign up with xbox live on the xbox console , you need a wireless adapter plugged in and connected to your wireless or a ethernet cable from the xbox to the router. Then just sign up for xbox live , you will receive a 1 month free trial of xbox live gold which will allow you to play people online, after the month trial you either pay for it or you are demoted to xbox live silver
Turn
off the Xbox 360 by pressing the power button on the front of the
console. Afterward, shut off your modem by unplugging its power cord.
Insert
one end of the Ethernet cable into the Ethernet port located at the
back of your Xbox 360 console. After that, insert the other end of the
cable into your modem.
Replug
the power cord into your modem to turn it back on. Once it is active,
press the power button on your Xbox 360 to turn it on.
Navigate
to "My Xbox" then "System Settings." Afterwards, select "Network
Settings" then "Test Xbox LIVE Connection." You will be notified
on-screen if the connection is successful.
Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection. 2. Turn on your xbox 360 and go to the xbox live tab. 3. Go wher it says Join and follow instructions. You can put your credit card info. or buy a prepaid xbox live card
Before you
connect any cables, turn off your router, modem, PC, and Xbox 360
console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem
and the other end to the Ethernet input port on the back of your
router.
With another Ethernet cable, connect one end to one
of the router's Ethernet output ports. Connect the other end to your
PC's Ethernet port.
With the third Ethernet cable, connect
one end to another of the router's Ethernet output ports. Connect the
other end to the Ethernet port on the back of the Xbox 360 console.
Turn on your modem, then your router, then your PC.
Make sure your PC can access the Internet. If not, you may need to
configure the router for Internet access. For help configuring the
router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console and sign in with your profile.
If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console with no disc in the disc tray.
If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
If you are looking to connect two XBox consoles together for offline play, the method can vary depending on the type of XBox you own.
For the original XBox, there should be two supported methods. The first allows you to directly connect two XBox consoles together using a "system link" or Cat 5 Ethernet crossover cable, while the second is to connect up to four XBox consoles using standard networking cables and an Ethernet hub.
With the XBox 360, there should be three methods available. The first is to directly connect the two consoles using a traditional Ethernet cable (RJ45), the second allows up to 16 different XBox 360's to connect by using standard networking cables and an Ethernet hub, while the third uses either a wireless router or the XBox's built-in Ad-Hoc networking tools to make a connection.
If you are unsure how to set up the consoles using any of these methods, you should be able to find step-by-step instructions in the owner's manual for your XBox, or by simply visiting the support section of Microsoft's homepage.
if you want to play online, with other people i am assuming? then what you would want is xbox live. you do have to setup a stable internet connection in order to connect to the internet*. and also you do have to pay a membership fee in order to stay in xbox live.
* and if you want to connect xbox live, you need a cable or dsl connection, either you need an ethernet cable or a pre-tuned wireless usb that is made only for the xbox 360. and also, you would need a cable/dsl company that is accepted by xbox live. and then go to the xbox 360 dashboard, then, click "join membership",
Path #2:
setup an ethernet connection either directly, or with a router/hub, then go the system settings, and click, "computers" and then click connect. but this path way is only to create a connection to the computer.
