Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Mixer The metal rod that allows the mixer to be raised and lowered so the beater does not hit the bowl has gradually moved until it fell out from the back. I am not able to get it back in. Can I do it myself? Mary
  • pervin Dec 01, 2007
    I have the same problem
  • malkah Dec 19, 2011
    thanks to the person who posted a solution. it worked and i am back in business!
I called kitchenaid. and i am repaired. lay mixer on its side. then you can see how rod needs to line up. loosten screw a bit if necessary. then tighten back up. very easy solution!
Posted on Dec 22, 2007
Beater hits side of bowl
What part number did you order for the beater and what is the model number for the mixer? Also is the mixer brand new, or did you get it used and it just started happening?
Jun 17, 2013 | KitchenAid KSM150PS Artisan Series Stand...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Beater rubbing bowl
Although I can't find your mixer by the model number you gave me, I assume that your mixer is the kind which the bowl moves up and down not the "tilt-head" style.
See pg. 12 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707946.pdf
There is a screw in the base of the mixer which is turned
clockwise to raise the bowl
and counterclockwise to lower
the bowl.
Apr 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
I need to lift the head a little. the wire whip
Hi LEDAVETORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Turn scre3e30899.jpgw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 11, 2009 | Food Mixers
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Mar 20, 2009 | KitchenAid Artisan Series Tilt-Head Stand...
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
272 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
