Question about ViewSonic PJ501 Multimedia Projector
Projector screen colors
My projector is missing the blue color on the screen. The blue .7 inch p-si tft screen burned out. where can i buy an after market .7 inch replacement screen? Or if the whole video lens assembly needs to be replace where can i purchase one. Ive tryed view sonic. they told me that some of the parts are discontinued.
5 Suggested Answers
SOURCE:
SOURCE: view sonic projector
Go to menu and choose option. Then choose lamp time or filter time, depending which one you want to reset and keep pressing reset-button for 3 seconds
Posted on Aug 22, 2008
SOURCE: VIEW SONIC PROJECTOR IS NOT STARTING UP
Sounds like it needs a new bulb
Posted on May 05, 2009
  • 489 Answers
SOURCE: Can't project video from laptop connected to NEC NP100
you can plug in to a laptop if the laptop has vga out. affter plug play the film or something and give the view to projector. need to pushing special button on keyboard. which is with FN
Posted on May 30, 2009
projdoc
  • 2239 Answers
SOURCE: my view sonic pj506d projecter fell and now has no color
it is called a color wheel, and you can buy it on-line from the viewsonic website:
http://store.viewsonic.com/html/vsc_ibePPSerialNumSrch.jsp?minisite=11174&site=&respid=52561&language=US
Posted on Sep 02, 2009
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Missing blue region
It sounds like the bulb overheated at some point. Time to replace the bulb.
Oct 31, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Color of projector output weird
Have you checked the cable (connectors) for good contact.
Mar 14, 2014 | Dell Inspiron 6400 Notebook
I have red and blue color tones to one side of my screen. And a slight blue haze at the top of the screen.
You have delamination/polarizar burn requiring factory authorized service.
Good Luck
Aug 11, 2010 | NEC MT1075 Multimedia Projector
Screen is incredibly dark, as if it was burned; cannot adjust color, tint, brightness, etc. When we bought the tv, it had a beautiful color, but now...
The LCD back light has blown, to buy a replacement you will have to visit the naxa site and see if they do spare parts, or can give you a contact number for repairs. Because it is a small lcd changing the back light might be tricky, it might be worth taking it to a repair store to see how much it would cost for the repair.
I hope this helps a bit, sorry i cant give any more info on how to get a replacment part.
Mar 23, 2010 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Sanyo Z3 Blue Color Problem
the LCD Module of your projector in blue panel is burn so that you can it larger and larger. replace your lcd blue panel. and also the mirror inside your optics.
Oct 08, 2009 | Sanyo PLV-Z3 Multimedia Projector
Blue spot on screen
there are light filters at each of the 3 lcd panels in the optical engine with a coating on them that determine the color. one of them (most likely the blue) is burnt from the heat and needs replacement. it could also be the fly-eye lens (whick evenly distribute the light) has burned as well. either way, it's very involved to replace, if you can get the parts. it's easier to have it sent in to get repaired.
Jul 31, 2009 | Canon LV-LP11 Projector Lamp for LV-7345,...
Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
May 05, 2009 | Dell 3400MP Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
ViewSonic PJ501 Multimedia Projector Logo
90 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Joaquim Martins
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
