The red "Lock On" light is flashing. I looked to unplug it, but it seems to be directly wired because there is no plug-in under the sink. I turned the breaker off then on, but it is still flshing. Is there a series of buttons to push to reset?
Try pressing the NO HEAT DRY or AIR DRY button for 4 seconds. The light should blink then go out.
I think the first digit of your model number should be a 6 instead of a 1. 665.15812992
Post back to let me know what happens.
Thanks/Mike
Try alternately pressing the air dry and hi-temp scrub buttons 4 times. Or air dry and sani rinse, whichever applies to your machine. All the lights will come on.
This puts the machine into the diagnostic cycle.
It will activate all functions of the washer.
If it won't go into diagnostics or the lock light is still on, you will have to replace the control board or console.
Since the light is flashing instead of glowing steady, I expect there is a stuck or shorted key on the console.
Thanks/Mike
You're right about the model number--sorry, typo. I tried your solution, but it didn't do anything. So anything else I can try to avoid a service call?
You're right about the model number--sorry, typo. I tried your solution, but it didn't do work. Anything else I can try to hopefully avoid a service call?
