Question about Kitchen Appliances - Others
Need instructions for model j4R star popcorn machine
  • 2 more comments
  • Anonymous Apr 15, 2008
    doesnt work
  • lisasdesigns Dec 15, 2008
    need to know how to make popcorn in machine
  • Anonymous Dec 21, 2008
    Instructons to use Presto Air popcorn maker
  • rose_webber2 Dec 22, 2008
    need instruction manual
    Problem Solver:
  • 9 Answers
Which model?
go here and put in the model number, a link to a manual may show up:
http://www.helmangroup.com/nostalgia/default.asp?a=service
Posted on Feb 04, 2008
The instruction manual can be found at the bottom of this page at this site: http://www.helmangroup.com/nostalgia/default.asp?a=service
Posted on Feb 25, 2009
Model 5916052 popcorn popper
Star 59 is an 8oz popper, they stopped making them in 1992. Parts are becoming very expensive, usually better to dispose of the machine.
I have some used parts available, depending on which ones you want, or you could try partstown.com for Star parts.
Jun 12, 2013 | Star Manufacturing Kitchen Appliances -...
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
Mar 09, 2011 | Nostalgia Electrics KPM-508 Popcorn Maker
Do you need to add anything to the popcorn machine
Depends on your machine. What bran/model dso you have? If it is an air popper, NO. Adding anything will damage the machine.
If your machine is not an air popper then you likely need to add some oil. I currently have a WestBend Stir Crazy Popcorn Popper. You use a tablespoon of oil for each 1/4 cup of popcorn in the bottom of the popper. See here; an instruction manual is available.
You are best to check with the manufacturer of your popccorn popper.
Jan 30, 2011 | Kitchen Appliances - Others
What is the Difference between A Star 39 and A Star 86 Popper. Mine looking Identical But Model is labeled as 59
I was able to find out that the Start 39 popcorn makers are 6 oz capacity. The star 86 models are 8 oz capacity. I could not find a model labeled "Star 59"
Here is a link below to the manufacturer's website that should help you.
http://www.star-mfg.com/Scripts/Category.aspx?cat_id=11
Best Regards,
Mark
Jan 19, 2011 | Star 39 JetStar Popcorn Maker
Star J4R Mini JetStar Popcorn Maker is not working
here is the manual download link
http://www.star-mfg.com/documents/Manuals/Star/Popcorn/C_JR4_MINI-JETSTAR_-_2M-Z4430.pdf
but you should also contact the manufacturer to ask specific question.
Good Luck.
Contact Technical Service
For questions regarding your Parts Order email your question to: Parts@Star For questions regarding your Warranty email your question to: Warranty@Star For Technical Information email your question to: Technical@Star For questions regarding Documentation order email your question to: Documents@Star
Or if you prefer - Call us or Fax your request using the following numbers: Domestic Customers International Customers
Phone : (800) 807-9054 Phone : (314) 781-2777
Fax : (800) 396-2677 Fax : (314) 781-4344
Dec 21, 2009 | Star J4R Mini JetStar Popcorn Maker
No instruction book
read a comment from some one that had the same machine.
Jun 18, 2009 | Nostalgia Electrics Helman Group CCP-509...
Well pump
i bougth mini jet star popcorn machine in a garage sale but without instructions and i don´t know how to make the popcorn
Jun 22, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
2,213 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
