Question about Prima C2012 TV
Now using satellite dish
When I switch on tv all i see is cable mono ch03 and I am unable to pick up signal from satellite receiver which supposedly is working according to satellite company. Could you maybe tell me if I have accidentally hit a button on remote to cause this.
  • 2 more comments
  • jdnorth Dec 01, 2007
    no the menu does not appear and when the satellite company resent booster, they said that everything looked good from there end.
    I was not trying to insult only trying to respond and guess what some people (ie me) are not as smart as you at all this and while I appreciate everything you are doing from long distance, the problem I came to you with happened after all was working fine and then a week later this happened, so therefore I was trying to fine out if it was my own dumbness that had caused the problem..... so if you think I was dissing you for your help, then whoops so sorry to hurt your feelings as I did not mean to.
    the booster I meant the they tried to redo ..... I quess send some kind of signal to receiver and stated tht everything from their end seemed okay.
  • jdnorth Dec 02, 2007
    okay will do and thanks
  • 934 Answers
Not likely - - there is nothing on the remote that would cut-off the signal, unless you have selective inputs and you were not viewing the correct one. However, "cable" CH03 is correct if your satellite is attached to the screw-on "F" connector in the back of the Tv... When you press menu on the reciever does a menu appear on-screen??
Posted on Dec 01, 2007
  • William Rayburn
    William Rayburn Dec 01, 2007
    What pray tell is a "booster"?????? Did the dish people even come out to your home? I don't really care at this point how poorly you've rated this - I'm still going to comment because the answer might be quite simple and absurd at the same time.. If the dish people didn't come to your home and physically test the signal they are idiots... If you didn't demand it then you're looking for an answer that doesn't exist...
    At the very least do what the idiot dish people should have done, hookup a different Tv to that signal source and see if it plays... If does not and has all the same symptoms call the idiots to come out and fix the problem.
    Lastly your initial question was, " Could you maybe tell me if I have accidentally hit a button on remote to cause this." and I answered that correctly although the rating you gave doesn't reflect that effort. So, I must say, in the twenty plus years I've worked in the electronic repair industry I have never been so insulted over providing the correct answer - for free...
    Have a good day!
  • William Rayburn
    With response to the booster thing - - they are idiots! Please son't accept that as their answer to your problem... Get another Tv and try it - I would strongly suspect that you'll have the same symptoms as you have now, which indicates it's their signal, box or some problem belonging to them and not your Tv..
Splitting a satellite signal to 2 tvs
Do you want to use a separate satellite receiver on each tv or just want to send the picture from one receiver to two tv's? It makes a huge difference. If you do it wrong you can damage both the satellite receiver and the tv, so be careful. Using separate receivers requires a multi switch near the dish. This is necessary because the satellite receiver sends a voltage up to the dish to operate the elecrtonics there. That voltage will damage the dish without that multi switch installed. an ordinary splitter will get the picture from one receiver to two or more tv's as long as the cable length is not too long.
Dec 29, 2013 | Televison & Video
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Unhooked all lines in back of tv cant remember to rehook up have2
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Can i get fm signal from a satellite dish we no longer use? This is still attached to the roof. I would like to use that coaxial cable from the dish and connect to my receiver.
No, you won't get significant signal in the FM spectrum from your satellite LNB coax. The dish is tuned to pick up signals of a very different frequency, and aimed to reject any signals not coming from a very specific direction -- up where the satellites are.
For FM, you need to receive signals from ground-based transmitters, in a different frequency range.
That said, you can totally use the coax to bring signals from your rooftop down to your stereo. To do this, you'd need to get up on the roof, disconnect the coax from your satellite dish and attach it to an FM antenna.
Best of luck!
Aug 09, 2009 | JVC Audio Players & Recorders
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Splitting satellite signal
standard spitter can be used for regular TVs. If the signal degrades, it can be boosted with an distribution amp, and could go to 100 TVs on channel 3 (for instance).
Jan 04, 2009 | Garmin KVH TV/SAT Switch SATELLITE...
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
Prima C2012 TV Logo
99 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
