Back to:
Tags:
Whirlpool Calypso GVW9959K Top Load Washer
Clothes getting sucked under agitator (by 9 users)
posted by gymcoach on Dec 01, 2007
I have a calypso GVW9959KQ1. My clothes are getting sucked down below the agitator. My best guess is that I need to either replace the whole agitator or just the seal????? What is the part number for those? Also, I have been getting black stains on my clothes. Even on my whites which have been bleached! Where is that coming from and how should I fix it? Thanks! ;)
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by deanafriedel, posted on Jul 28, 2008
I have the same problem but the machine is tearing my cloths as they are getting stuck under the aggrator
Comment by Guest, posted on May 10, 2008
Same thing happened to me. How do you get the lid off to get to the drum. I tired of paying sears to fix the same problem
Comment by MIKE 777, posted on Feb 11, 2008
Clothing comes out of Washer with black stains
Comment by Guest, posted on Feb 10, 2008
maytag la washer clothes stuck under agitator what to do i've pulled on the clothing and turned the agitator but their still stucvk its just a pair of boxer shorts so no biggie if i just need to cut them out
Comment by Guest, posted on Jan 01, 2008
We have a Calypso washing machine and have had 3 service calls on it and am ready for number four- #1 - we washed a bathroom rug in the machine and it stopped up the pump - #2Pump plugged again - was replaced
#3 loud squeals when there was just 12 min left on the machine . replaced the fill valves for the water softener dispenser- #4 will be - it is shredding all the towels - they must work themselves under the agitator and the threads are all just hanging. what do we do about this?????
Best Solution
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I, too had the problem with clothes getting stuck. We were still on service contract, so the whole washplate was replaced. We aren't getting the clothes stuck anymore, but I am having major problems with black stains on all of my whites...I'm going to call the service guy back because our extended warranty expires in april...the problem with the clothes getting stuck is because the rubber on the outside of the washplate wears down. The only way to correct it is to replace the entire washplate. This washing machine is the worst I've ever had!! It's not even 5 years old yet and I'm ready to get rid of it!!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Clothes getting sucked under agitator:
I don't want to Accept this solution
Solution #2
posted on Dec 27, 2007
FixYa! (100)
suttonjj
Rating: 93%, 9 votes
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Comment by suttonjj, posted on Dec 27, 2007
Ugh! It's been a long week. Should say "Check out steps 6 and 7 on page 36".
Thank You!
Solution #3
posted on Dec 16, 2007
Not Rated (0)
Lisa1218
Rating: 0%, 0 votes
I haven't found a solution yet
Comment by Lisa1218, posted on Jul 25, 2008
My machine finally stopped working due to the clothes getting stuck. It was still under warranty so the repairman replaced the entire washplate. Not even two weeks later, clothes started getting stuck again and now it is no longer working again. It is all of the little clothes, socks, underwear that is jamming the whole thing up. I hate this machine. I have now been without a machine over 4 weeks total time, I should have just bought something new with all of the money I am spending at the laundromat.
Thank You!
Can you Help with these Washing Machines problems?
When washing clothes, especially in the cold cycle (which...
Please help me! I have the same problem I just saw on this...
Have had this unit a few years and has been working well...
my washer will not spin or agitate , the code ci and ca i...
We have had this washer for about 7 years and it's been...
8 Other Users Have The Same Problem - Continued
Comment by suttonjj, posted on Dec 26, 2007
I have the same problem. Now I have a dinner napkin lodged underneath. Still researching how to remove "agitator".
Comment by Guest, posted on Dec 15, 2007
Did anybody solved this problem or find out the solution?
Comment by Lisa1218, posted on Dec 01, 2007
I have the exact same problem. The dark spots on my sheets and I now have a sheet stuck between the agitator and the wall.
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
