Question about Onkyo TX-NR801 Receiver
Receiver was dropped and now only the standby light will come on, but nothing else.
I am pretty sure that this is going to have to go to a repair shop, but what could it be and how much coul dit cost to fix? The receiver was dropped in a move. It was in a box, but not very well packaged (should have done it myself!). It took the hit in the back of the unit where the powercord goes into it. I took the cover off and could not find anything loose or visablt broken. When you plug it in and push the power button the only thing that happens is the standby light comes on. Ant help would be greatly appreciated. Thanks.
    New Friend:
  • 59 Answers
I don't want to be the one to say it, but there's a reason for the sticker that says 'no consumer repairable parts within.' If you have an electronic tech for a buddy, let him/her look at it.Shop time will run anywhere from $45-90 hr, with a 1 hr minimum. As low as prices are these days, consumer electronics are now 'throw it out, get a new one' items. Do us all a favor if you trash it. RECYCLE it. Take it to Goodwill, you local solid waste dept. just don't let it end up in a landfill.Odds are it's something simple but it'll cost to find out.
Posted on Dec 29, 2007
Won't power up.
It may be doing a "self check". Make sure no one crossed any output / speaker wires while moving speakers to clean, etc.
Jan 11, 2008 | JVC RX-7030V Receiver
Why is my RCA STAV-3860 not coming on?
It sounds like the unit is getting power but is going into standby mode due to an internal fault. Sadly, newer receivers these days are not designed to be repaired but replaced!
Jun 13, 2014 | RCA Radioshack 31-5003 Stav-3860 60-watt...
AMP ERROR DISPLAY NO VOLUME
This is how to reset the receiver to factory default- not sure if it is the same reset you would do for an amp error:
Resetting the system
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the front panel STEREO/A.L.C
button, press and hold
u STANDBY/ON for about two
seconds.
The display shows RESET?.
3 Press the front panel AUTO SURR/STREAM DIRECT
button.
The display shows OK.
4 Press HOME THX to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Note that all settings will be saved, even if the
receiver is unplugged.
Unfortunately, amp errors are usually not fixable and require you to bring the receiver on for repairs or just buy a new receiver.
THANK YOU AGAIN SO MUCH! I basically got through the 1st step or so and the thing came right back on like nothing had ever happened. Although, I think what ended up working for me was actually pressing and holding the STANDBY/ON button with the AUTO SURR/STREAM DIRECT button together for a few seconds....I didn't have to reset to factory settings, nor did I have to do step 3 or 4.
Now the receiver is working just fine like nothing ever happened. All of the input AND output speaker channels all seem to be functioning normally and in peak form, and I've made sure that I have the area around the receiver well ventilated. So....thank you, again...for getting back to where I really wanted to be without having to go through the hassles of disconnecting everything and having it serviced with possible $ and time expenses.
Oct 16, 2013 | Pioneer DEH X3500UI - radio / CD / MP3...
Unit does not reset
Sounds like it it going in to protect mode. Very likely to have a bad output transistor(s). If discrete outputs are used in your receiver they are the larger components mounted to the heat sink. Sometimes only one transistor shorts other times many transistors, diodes, resistors and capacitors go bad. Take it to a service tech if you or no one that you know has some level of amp repair knowledge. Good luck!
Jul 04, 2013 | Pioneer VSX-1022-K Receiver
Standby light on
You might have shorted out one of the amp channels. If this is the case, it needs to be looked at by a pro.
May 02, 2013 | Onkyo TX-SR502 Receiver
I have an AVR-745. When I turn the unit out of standby it powers up for about 2 secs then goes back to standby. This the 2nd time this has happened. The first time I sent it to a repair shop and it cost a...
Hey there.
I've also submitted my avr745 to rep. now but they can not find out what is wrong with it. they've had it for 3 months soon, to im getting pretty tired of waiting. you know how to repair your avr 745? Really need a solution to this problem soon.
Aug 13, 2010 | Harman Multimedia AVR 745 Receiver
Receiver shuts down and will not turn back on untill you unplug and plug back in
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
Sep 24, 2006 | Harman Kardon AVR 235 Receiver
Onkyo TX-NR801 Receiver Logo
65 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
