Washing machine hi .. i got fisher & paykel 703 washing machine ..its power on but nothing happen .. can you help me please..
    President:
  • 1,294 Answers
Plug off the wall. Open up behind to see if all connections a fitted securely. Especially from the control unit to the motor................
Posted on Dec 01, 2007
SOURCE:
Got MW512 washing machine.turn power on ,lights come on per usual. hit any program to wash but wont start agitating.help.
Hi - its highly likely the start/pause micro switch under the nice panel is faulty, only way is to replace the display module.
I have come across machines with same problems where you can select any function except of course - push start & nothing happens., if your machine does this then I suggest you invest in a replacement display module.
Jun 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 703 top loader, lights go on but pressing them even to start does nothing not start or let me change the size of the load ;(
Hi, just read your posting.Now the possible fault could be your display board.When you turn the power on to the machine from the power point do all the lights come on and you hear an audio beep beep , then the lights go out ?If that happens, then do you push start and can not select anything else like water temp or load size?Or do a series of lights light up and it beeps indicating a fault code after you have pushed the power button? Please reply and I can guide you throe step by step the process needed to fix this problem.
Jun 05, 2010 | Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Beeping BUT not Starting
This sounds like a speed sensor problem located on the motor.e.g. when you turn your washer on ,as the water comes in the tub turns if it dosen,t the speed sensor (if crook)doesent send the message to the processor and will go into fault mode.If lid & out of balance switch are ok then this will be your problem.Kind Regards.
Jul 07, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
