Question about HP Compaq Presario V2000 Notebook
Screen display problem
I have a Compaq Presario v2000. When I power it up the LCD display will only come on if I open it up a couple of inches then if I open it more it goes black. Sometimes if I move it slowly it will open up a little more before going black but I just can't seem to find the problem.
Thanks for your help.
    Genius:
  • 1,601 Answers
Sounds like a loose ribbon cable from the MB to the screen.
Here is a manual that should help you take it apart.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Posted on Dec 02, 2007
Display problems
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 13, 2013 | HP Compaq Presario V2000 Notebook
The small rubber button on my compaq presario V2000 isn't working. When I open the screen of my laptop the light on the screen will switch on for just a moment, and then switch off. How can I fix it so the...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 08, 2011 | HP Compaq Presario V2000 Notebook
I have a Compaq Presario V2000 and am on it right now but the screen is black and I am using it by pluging it in to a diffrent screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Red and green patches on my lcd laptop screen
have you ever seen the 10 inch lun, so dear use it
Mar 04, 2009 | HP Compaq Presario V2000 Notebook
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
LCD screen blank out
look at your function keys (F4 F7) from what i can see on the picture but it will somehow resemble an lcd screen. Try to push the Fn button along with the F-button that has the "lcd" picture at the same time. If this does not work pushing it once try to push it twice. After each time release both buttons and wait a couple seconds after each attempt and see if this fixes the problem
Jan 16, 2009 | Compaq Presario 1200XL104 Notebook
LCD Screen is black
It could be either, if you can get another LCD screen (same make/model) you can swap to ckeck it out.
You could check the inverter by touching its output and if you get a bit of an electrical shock then you know the inverter is working or check it with a multimeter if you don't like electric shocks.
Dec 27, 2008 | HP Compaq Presario V2000 Notebook
Screen
Try pressing Fn-F4 a couple times. Sometimes people accidentally enable the external screen and disable the internal one. If this doesn't work, try plugging an external screen in. If the external works then you might have a dead display.
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
White screen
Use an external monitor all should be ok the LCD screen is faulty you can enquire about it here:
http://lcdrepair.net
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
