Danby 60Pint Dehumidifier with Remote Dehumidifier
Problem for Danby 60Pint Dehumidifier with Remote Dehumidifier
Why is there a burning smell coming from my
By raicheeffect on Aug 16, 2009
why is there a burning smell coming from my shcc6026 when in dehumydifying mode
Solution #1
posted on Aug 16, 2009
Not Rated)
Mx Man
Rank: Wiz
Rating: 79%, 24 votes
It sounds like there may be wires touching each other inside the machine. You may not want to run it until you take it apart and check for burnt wires and definitely don't run it unattended.
Was this helpful?
Yes
No
Popular Solutions for Danby 60Pint Dehumidifier with
Questions and Unsolved Problems for Danby 60Pint Dehumidifier with
Do you recommend Danby 60Pint Dehumidifier with Remote Dehumidifier?
Answer
Answer
I got this from my neighbor, i want to use it as dehumidifier, worked well but then the intenral... (More)
Answer
i lost the user manual and i have always `e7' flashing and not working just use it as a... (More)
Answer
Ice is building up and coming through tth efront of unit at the bottom where the filter is. What is... (More)
Answer
When the top bucket is filled for humidifying, the reservoir below it fills and starts leaking out... (More)
Answer
how do i work it where do i set the levels at
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby 60Pint Dehumidifier with...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
