Question about Sony DAV-C700 System
DAV-C700 overheated My DAV-C700 overheated and turned itself off. Is there anyway to fix it?
    Problem Solver:
  • 8 Answers
A lot of "aged" problems relate to the power supply with this type of unit. If you are a handy chap and know what capacitors are you will find that finding and replacing the "dry" caps in the power supply will fix most problems including streaky pix and crackly audio.
Posted on Mar 10, 2008
SOURCE:
How to remove protect on a DAV-TZ140 ?
Repair the damaged amplifier section.
May 05, 2014 | Sony DAV-C700 System
Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Jun 28, 2008 | Sony DAV-C700 System
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
My DAV S-400 only works for 5 minutes and then stops and does not work anymore.
Something is overheating which is causing the unit to shut down to protect itself.
Try disconnecting the speakers and see if you get the same result.
If you do then the fault is with the Power Supply, if not then the fault is with the Amplifier.
Apr 28, 2011 | Sony DAV-S400 System
Sony DAV-C990 can't get it off the standby mode
Unplug DAV-C990 from AC outlet for couple of minutes, replug back in and power it up. If problem still exist then home theater has got problem in amplifier output section. Let me know the results to help you more.
Jun 12, 2009 | Sony DAV-C700 System
Lines on tv
Jan 27, 2008 | Sony DAV-C700 System
Poor picture quality
Jan 02, 2008 | Sony DAV-C700 System
Sony dav-c990 not functioning
Nov 22, 2007 | Sony DAV-C700 System
Sony DAV C700 DVD Player
Nov 13, 2007 | Sony DAV-C700 System
Sony DAV-C700 dvd player not responding
take it to a authorised technician and get the lens reading circuit replaced it will work
Jun 12, 2006 | Sony DAV-C700 System
Sony DAV-C700 System Logo
251 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
