Question about Epson Stylus Pro 4800 InkJet Printer
Epson 4800 Firewire Port Connection with VISTA 64
Latest Vista 64 Driver for Epson 4800 does not find the 1394 firewire port...and you can not assign it manually to firewire, The USB side works ok. I would like to get the firewire connection working. The error you get when you look at the firewire yellow exclamation port is error code 39 and its a plug and play error. The message in dev mgr indicates the driver cant be loaded, may be corrupted etc...then aggter not finding the firewire port the driver reverts to a LPT1 parallel port connection. It may be Epson just didnt do the firewire part of the driver...this works well with XP/SP2.
Any ideas?
Alex
  • Anonymous Feb 27, 2009
    Just ran into the same issue with my 4800 and sadly it appears Epson has done nothing to address this legacy support issue. Frustrating when firewire worked perfectly under XP.
    Epson: Poor Marks
    Microsoft: Poor Marks
    Genius:
  • 1,447 Answers
Hi-
You can find info from this link EPSON
Posted on May 19, 2008
Vista 64 does not support ieee 1394 port.I have same problem,been everywhere,going back to xp.64 sucks.
Posted on Sep 17, 2008
Can you advise -- what firewire cable do i use to connect PC with printer? Both PC and device have 1394 ports, but specs don't say pin number. (PC is new, so presumably has latest firewire standard; the...
The 4 and 6 pin have different shapes. The 6 pin is a larger rectangle and two corners are beveled. The 4 pin is a smaller rectangle with two corners having a sort of pointy extension. moz-screenshot.pngbb5f64d.jpg
Apr 28, 2010 | Epson Stylus Photo R1800 InkJet Printer
Need driver to transfer video to using Vista
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Dec 30, 2009 | Sony Handycam DCR-TRV18 Mini DV Digital...
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Fireware port is not sensing Sony camcorder
check if vista home edition supports it. other else uninstal & reinstal the driver.
Jul 03, 2009 | Microsoft Windows Vista Ultimate Edition
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
I can't get Firewire to work on my Sony DCR-PC101e.
No special soffware or driver is needed provided that your PC has a firewire port ...
Dec 15, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
SONY HANDYCAM DCR-TRV280
To download video you need Firewire port, also known as an IEEE 1394 port.
Windows XP or Vista can save your video files.
PCMCIA 2-Port IEEE 1394 FireWire Laptop Cardbus PC Card
Jun 26, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
1394 Fire Wire
I change my PC to new windows vista and the new PC don't recognize any VCR throw firewire, but the machine recognize my canon LG-2 by firewire. I need something special like a special driver to run my JVC's BR-DV3000 & BR-HD50 for capture video
in vegas pro 8.0?
Feb 11, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Epson Stylus Pro 4800 InkJet Printer Logo
389 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
