Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyostove laser 73 heater with a EE 2 error
My Toyostove laser 73 kerosene heater is showing error EE 2 which says is a missed ignition. We had this problem a month ago and changed the filter out and it started working fine again. We are not out of fuel and the filter is still clean and new. When the stove tries to start you can see a flame and after about a minute the error comes back on and the heater shuts off. Could it be the ignitor or what?
  • 4 more comments
  • Anonymous Mar 18, 2008
    same problem
  • Anonymous Apr 30, 2008
    Stove runs for approx one minute then shuts down and displays EE-2
    Have not done anything yet to fix problem. Cannot find anyone who will agree to service this stove.
    same problem..can not see a flame in the ignition process though. Cleaned the filter, and the pump is working properly. I am thinking of trying to replace the ignitor.? Any ideas out there?
  • elkindr Jun 05, 2008
    Stove runs for approx one minute then shuts down and displays EE-2. Can not see a flame in the ignition process. Cleaned the filter, and the pump is working properly. Have not done anything yet to fix problem. Anyone know of a fix? Don’t have an owners manual – any one know where to get one online?
  • Anonymous Jul 15, 2008
    My stove had a EE2 on it and I bled the carb, cleaned the sensor and ignitor. finally it started right up and no problems.
  • Dawn Hamel
    Dawn Hamel Nov 06, 2017
    We are having this problem right now with our heater anyone find the answer back then?
  • 625 Answers
Replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Posted on Dec 02, 2007
Same problems. Could also be the igniter (long white ceramic piece).
Have had to replace every 3 yrs or so. Although the burner will come on and run for a few minutes, when it kicked into "higher gear" EE2 error occurs. I have advantage of having two units, so can swap one out to make sure it is the problem before investing in new igniter.
Posted on Jun 23, 2010
We had the same problem... There is a bleeder valve directly outside the fuel tank. That needed to be bled and it started up right away!
Posted on Feb 25, 2009
  • Megan Sheehan Feb 07, 2011
    Same problem, snow came off our roof and was blocking exterior exhaust pipe. Cleared snow and it fired right up.
I had this problem, I was always in save mode and thought the heater may not be self cleaning so took it out of save mode and it is now staying lit and burning with a clean flame now
Posted on Feb 11, 2008
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
Jan 05, 2013 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 will not have ignition , it has fuel it start with a green light and in about 3 to 4 mintues the fan start to run then i get a error 2
ee 2 is the code for no ignition. This can be caused by a dirty fuel filter or dirty fuel strainer. The flame rod may need to be cleaned. The igniter may be burned out. Could also be a circuit board problem. If the fuel pump makes a loud ticking or thumping noise then it is a fuel flow problem and I would check the filter and strainer first. When checking the flame rod be sure to unplug the heater first.
Dec 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
Yoyostove laser 73 ee-2 keeps coming up which i know is missed ignition,but after a few times of missing ignition the k-1 leaks from the bottom of the heater what needs to be done about this problem?
Sounds like your igniter may have burned out. You can test the igniter with an ohmmeter. You can also check for voltage on the circuit board where the igniter connects. Don't try to start it again until you check the igniter because unburnt kerosene will just keep building up in the burner. Let me know if you need more help.
Nov 18, 2010 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 fire will start but the circulation fan will not start. will eventually overheat and then shut down with EE 2 error. Whats up?
Because you have the EE2 error I would say there is nothing wrong with the circ fan. Your are either having a problem with fuel flow or the igniter. Feel around the two red wires when you try to start the heater. If they get hot you have a fuel problem. If you also hear a thumbing noise you have a fuel problem.
Tom
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
Getting code EE 2 on a laser 73 toyostove that runs on kerosene
EE 2 usually has to do with the fuel. Does the heater make a loud ticking or thumping sound? That's the sound the fuel pump makes when its not getting any fuel. Check your filter, check the strainer in the fuel sump. Depending on how cold it is any water in the fuel line could be frozen blocking the fuel flow. You might also check the flame rod for soot. It can be cleaned with some steel wool.(nitensheaterservice@embarqmail.com)
Jan 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
I have a Toyostove Lasr 73 which started complaining of an EE 2 (ignition failure) on startup just this morning. The fuel lifter seems to be working and I can smell a bit of kerosene in the heater, so I...
An EE 2 message can mean 2 things
Ignition never happened or unit did not sense flame
You should see the Igniter glow through the peep window during
pre-heat, easy er to see with front cover off.
If you do see a glow and flame happens, but unit still errors out.
Try to clean flame rod sensor.
Unplug unit.
Single white wire going to burner pot. (pull straight down)
2 screws hold a plate
Turn sensor to 3 o'clock or 9 o'clock position
pull sensor out easily
Clean sensor with sandpaper- down to shiny metal
Good Luck
Dec 14, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove L-73
I have used #2 in the summer. I have been told the difference between 1 and 2 is 1 has an additive so it won't free. I would use oil meant to be used as heating oil because it should be lower in sulfer.
Nov 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 ee 2
try this site....
http://www.rural-energy.com/publications/catalog/category/101
How long has it been since you've cleaned your stove? If it's been a while the flame sensor (the part with the metal rod) may be building up a chain of carbon blocking the igniter from igniting the flame. A temp fix is to jiggle the sssensor but what is needed is a cleaning. Also you may need a new burner ring. That solved my problem last winter.
Oct 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
5,602 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
