Question about Sony Cyber-Shot DSC-F717 Digital Camera
My Sony digital Camera DSC-F717 lost it's vision. I can see existing pictures from my memory card however camera does not see new pictures. What can I do? The pictures started getting lighter and Lighter then stopped all together.
  • Sony Master
  • 497 Answers
May be the issue with the CCD (image sensor device) of the Camera. This is a known issue with this Camera.
Refer this article to confirm this:
http://esupport.sony.com/US/perl/news-item.pl?news_id=161&mdl=DSCF717
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click on the "Yes" button at the end of the page to create an online Repair Request for sending the Camera to the Sony Factory Service Center.
Posted on Sep 02, 2009
SOURCE:
I have dsc-f717 and i lost some pictures i can not find it in memory stick ?
Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
http://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
Mar 23, 2012 | Sony Cyber-Shot DSC-F717 Digital Camera
Camera freezes
Does the camera work ok now? I suppose you should have offloaded the pictures before pulling the battery. What was the question?
Oct 08, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Dsc-f717
The Sony DSC-F717 will only take upto a 256MB Memory Stick - larger size Memory Sticks will give the C: 13:01 error. Use a correct memory stick and your camera should be fine. Regards, Andrew
May 10, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony dsc-f717 memory stick error I have a problem with my camera mentioned above, error number is C:32:01 that shows after I take several pictures or a short video. I changed the memory card into a new one...
A letter and number error code of C:13:xx is an indication the recording media (floppy disk or Memory Stick® media) you are using is either not supported for use with the camera, not formatted properly, or is damaged or faulty. Since you have swapped out the memory already and reformatted it, we'll probably have to assume that the reader is dirty. But first make sure that you re-formatted the stick using the camera, not a computer, as Sony claims that a computer format is not supported.
CLEANING THE READER
Blow into the stick slot with a can of compressed air, using a q-tip. If it still doesn't work you may need to buy a commercial memory card slot cleaner.
May 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
I have a sony dsc-f717 took several pictures and now i get format error 13:01 and can't retrieve the photos I've took and veiwed. Help retrieving
1st, try and download the pictures via your computer and a memory card adapter. If you're computer doesn't recognize the card through an adapter,
2) go to www.ita.sel.sony.com
Search by the model number of the Memory Stick. There is Memory Stick recovery software. follow the steps for the download and recovery.
3) On new/blank memory cards, I sometimes have to format the MS in the camera first, then everything works fine.
Jun 28, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Memory sick error
dear sir
I have a problem in my yber-shot DSC-F717 digital camera. There is error in stick memory code number C:13:01
Mar 18, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Memory stick error
Hi There, In the menu there should be a setting to set the camera back to factory. Try re-formatting the card. Try using a different card. The camera has some built in memory, take card out and shoot 2 pics on built in memory, is playback ok?
If not, card reader may be defective. Only service shop could tell you that for sure.
Let me know, mr cicmo.
Dec 28, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Memory Stick reformatted in new camera
Digital Camera and Video Phone Number 1 800 222 7669 - it's automated, just say your model number, then "no" to accessories, then "no" to connection problems, then "picture" for ccd issues. Its that easy!
Dec 19, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
