Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
Problem with y toshiba 53hx71
When my tv is on it starts making static like noise and the image gets messed up . does anyone have or heard of this problem or seen this before
any suggestion will be greatly taken .
  • 2 more comments
  • tito28 Dec 01, 2007
    where can i find this board and what about the noise.
    the picture only goes away when the noise happened.
    it so bad it sounds like a thunder and my dog goes
    running.
    Thank you I would like to be around for the holidays. about how much would something like that cost. It's better to buy a new tv or to fix it.
    Thank you so much.
    i will look around for a shop.
    have a good holiday season.
  • Gene L. Feb 09, 2008
    I had the same problem after 2 years of use. The repair shop came out and replaced the digitizer board which took about 2 weeks to arrive after it was ordered. I don't know how expensive it was since the warranty was still in place but I would imagine somewhere in the $600 range.
    I would suggest you think twice before spending on this. I now have had the TV six years and the convergence circuitry seems to be the cause of a problem where the picture is completely distorted for about 10 minutes after turning it on and then flutters at various rates for the remainder of the on time.
  • 934 Answers
Tito,
There is a fairly common problem with those symptoms. Try removing the srs-wow board, stand-up audio board next to the tuner. If the picture clears up it's likely QD01 on the srs-wow board loading down the scl & sda lines. QD01 is an Njm1136d Toshiba p/n# 23009142.
Bill
Posted on Dec 01, 2007
  • 2 more comments
  • William Rayburn
    William Rayburn Dec 01, 2007
    I didn't realize from your original post that the static noise was that loud... I am fairly certain that the srs-wow board couldn't do that - what you're describing sounds like a high voltage leak and not something that you want to take a screw driver too and go probing around.. You might find it that way, but it might be the last thing you do find on this earth...
    If this is static is as loud as all that Tito get that unit into a ahop. They have both the equipment and experience to locate the problem and fix it without anyone getting killed...
    Bill
  • William Rayburn
    All depends on what's found to cause the root problem.. For example, I've see coolant leaks cause the anode to find ground causing a static hissing... I've see HV splitters or the flyback transformer fail and cause this problem... It's really ging to be hard to tell but I would guess somewhere around the $500.00 dollar mark would be about average... That's based on my shop rates at $60.00 an hour and rough guessing at the parts...
    Good Luck!
    Bill
  • William Rayburn
    PS: Take the unit to them, don't have them do the pick-up/delivery and you'll save a bundle.
    Bill
  • William Rayburn
    William Rayburn Dec 02, 2007
    You're quite welcome - have a great holiday season also...
    And please don't forget to rate this with Fixya when you get all done..
    Bill
SOURCE:
Toshiba 53hx71 blinking red light when p83 to p803 is connected
I have a 53hx71 that is haveing an issue with my blue on covergence. I have replaced both the chips and it still wont move up or down when i try to adjust manually and the auto adjust wont work either can anyone help?
Dec 08, 2013 | Toshiba 53HX71 53" Rear Projection...
The screen of my Toshiba projection TV model # 53HX71 has red and green shadows. How do I fix it? Can I do it myself? How much will it cost to fix?
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
May 14, 2011 | Toshiba 53HX71 53" Rear Projection...
My Toshiba 53HX71 takes about 20 minutes to "warm"
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Apr 09, 2011 | Toshiba 53HX71 53" Rear Projection...
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
How do I remove the screen of a Toshiba 53HX71. I
You do not remove the screen on that TV. Doing so will mess up your convergence.
Chassis must be removed by a professional.
Call the manufacturer to find you nearest authorized service center.
Mar 24, 2009 | Televison & Video
1/2 the screen is blurry
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Toshiba 53HX71 53" Rear Projection...
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Do the wheels easily come off this unit?
They should just be standard casters on the bottom. The tough part is laying the TV on its side to remove them.
Feb 07, 2007 | Toshiba 53HX71 53" Rear Projection...
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
