Question about Denon AVR-887
My Denon AVR-887 Keeps turning itself off
I am having a problem in that every time I turn it on,my Denon AVR-887 turns it self off about 30sec later. Is there some sort of setting that is doing this? How might I fix this?
  • 2 more comments
  • marks girl Jan 01, 2008
    mine is doing the same thing. I rebooted the microprocessor and this is the end result. shutting off and remaining on for approx. 10 sec then off
  • pgoods Sep 24, 2008
    I have the same problem. I tried reseting the microprocessor, which reset, but didnt change anything. i turn it on, and it shits off in about 30 seconds. it will not stay on. i did a trial and error, its not plugged into anything and it still shuts off.
  • Anonymous Mar 25, 2014
    Tried to update firmware. Got message that update failed. Now every time it retries to update I get message that connection failed. I can't access anything now...it just keeps saying connection failed
  • Dennis McCollum Jul 21, 2016
    you will have the +and- 15volts regulators transistors bad. check those suppplys as one will be bad
    New Friend:
  • 95 Answers
Troubleshooting:
The Unit turns OFF it self after 10-30 sec.
Test:
- Detach 5pin cable which going from AMP Bar Code to HDMi PCB (Board)
-Turn ON the power of unit
If Unit will power UP and doesn't turn OFF.
Solution:
More chance malfunction HDMi board but for sure
have to test triodes of AMP Bar Code assy.
Posted on Nov 13, 2013
My AVR-887 IS SHUTTING OFF ALSO AFTER ABOUT 30 SECONDS.
Posted on Dec 04, 2008
    Problem Solver:
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Posted on Jan 09, 2008
SOURCE:
Does DENON AVR 887 support HDMI ARC? I bought the unit around 2007.
The Denon AVR-887 does not support ARC (audio return channel) on the HDMI output. You can find the specifications for the AVR-887 in the manual. ManualsLib has the manual here: https://www.manualslib.com/manual/38390/Denon-Avr-887.html . The specifications are listed here: https://www.manualslib.com/manual/38390/Denon-Avr-887.html?page=77#manual . The page with the monitor connection is https://www.manualslib.com/manual/38390/Denon-Avr-887.html?page=22#manual .
I hope this helps.
Sep 24, 2018 | Denon Audio Players & Recorders
Denon avr-887 code for comcast silver remote, red key. The 2 codes comcast gives me do not work. Any other codes known?
These are the codes that I have from a few extra sources. They are for ALL Denon receivers/tuners: (3 digit = 262,307)For the AVR all numbers consisting of a 4 number code, all begin with a "5". Here they are: 5006, 5048,5054,5085,5129, 5130, 5131, 5132, 5133, 5134, 5152, 5159, 5160, 5168.I was able to get my 529 rc to program some of the features but I will go back and try other codes that may have a better "fit" and operate more features. Hope this helps!
Sep 05, 2012 | Denon AVR-887
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
It turns on flashes green then turns off
Missing some cable connection between
boards. Check cable.
If all cable intact connected try-unplugging cable one by one then power ON. Plug back unplug other one. Start from cable, which attached to HDMi board.
Oct 02, 2011 | Denon AVR-887
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
My Denon AVR 3806 keeps turning itself off, why?
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Jul 06, 2009 | Denon AVR-3806 Receiver
Denon AVR-887 turns itself off in 5 secs, any one know why?
You might have the polarities on the speakers crossed, check all speaker connections to make sure the pos and neg are connected correctly. If they are crossed, this will cause the receiver to short out, thanks
Apr 05, 2009 | Denon AVR-887
Denon AVR 887 Upconversion With Wii
I have this hookup and it's working almost perfectly:
Wii --component--> Avr-887 --HDMI--> Sharp LCD TV
Sometimes the pictures don't show up during start up, but I figured it was (probably) due to Sharp's HDMI handshake issue, so I turned the TV off and then on, everything works.
Mar 20, 2008 | Denon AVR-887
Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Dec 26, 2007 | Denon AVR-887
Denon AVR-887 Logo
2,582 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
