Dishwasher not cleaning dishes. Casade cleaner not disolving.???
Water not hot enough or not enough water pressure?? Don't know who to call Kitchenaid or plumber. New dishwasher.
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
There is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com. this will fix the problem. it fits under your sink and is easy to install. the detergent has a hard time mixing with hard water. this should work.
SOURCE: Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
